me thinks that you have some options. you could get 2-4 channel amps and drive 8 of the stockers (does this have monsoon?) or you can use the existing amp by hacking your pc audio out to the audi amps inputs- this may be difficult if you cannot locate a pinout of the audi's stock amp- my buddies b5 vw has an amp mounted in the passenger side of the trunk, if yours is similar I'd go with multi channel sound card hacked to audi stock amp- you'll need to figure out how to get the amp to switch on- oem amps have the same features as decent after markets- they just come in harder packages- not everyone needs to adapt things to it. I am a big fan of the vw monsoon system- after hearing it I am completely revamping my BMW audio system.
LinkBack URL
About LinkBacks
