Results 1 to 10 of 12
Thread: Which side of the distribution block should the inline fuse be?
    May 2006
    Calgary, Alberta
    Should I put the inline fuse for the amps on each amp power wire going into the distribution block, or just one on the other side going to the battery?
    Basically I plan on running 8 gauge from the battery to the distribution block and then another two 8 gauge from the distribution block to the amps. And somewhere in there I'd squeeze the 18 gauge power wire for the computer. Any problems here?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Colorado, but Canadian!
    I would put a big one one the main line close to the battery. And then a fuse for each "accessory" on the power distributor, close to the distributor. That way if 1 thing is bad, the individual fuse blows, and if something catastrophically bad happens, then the big one blows. Always good to have a contingency plan too, so 2 fuses essentially to each device is good, in my opinion.
    1.9in x 2.9in -- 47mm x 73mm
    Newbie bob^'s Avatar
    Jun 2005
    Geelong - Australia
    Not to mention the smaller cables comming out of the distro block have a lower current rating. Whilst you might have a 250amp fuse near the battery which is fine for the main cable, 4 guage would melt with less than 250 amps I'd say, and you can see where that would lead to.
    2004 Ford Falcon XR6
    Newbie hunterius's Avatar
    May 2006
    Slovakia
    250A fuse will stand even starter
    anyway one big fuse on main cable max. 30cm ( 1 feet) from battery and if you will notable lower cross-section of wires running from distribution block it is definitely good idea put smaller fuses on each wire right behind the block.
    "We cannot solve our problems with the same thinking we used when we created them."
    AE
    May 2006
    Calgary, Alberta
    So what size fuses do you think I need for these?
    computer
    120 watt 4 channel amp
    250 watt mono amp
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Slovakia
    there is simple formula : wattage peak + 10%
    if your numbers is peak so let say:
    -main source 90 - 100A fuse
    if your wires from distr. block is short enough , apms and PSU has its own fuse, so you don't need any other fuses. But I think that your 8awg wire from battery to block is insufficient ...you need 4awg.
    and here is recommended maximum fuse for vary wires
    00 awg 400 amps
    0 awg 325 amps
    1 awg 250 amps
    2 awg 200 amps
    4 awg 125 amps
    6 awg 80 amps
    8 awg 50 amps
    10 awg 30 amps
    12 awg 20 amps
    14 awg 15 amps
    16 awg 7.5 amps
    and here http://www.bcae1.com/wire.htm you can find a lot of information you need
    AE
    May 2006
    Calgary, Alberta
    Okay, so here's my plan of attack then.
    4 gauge wiring from battery to distribution block in trunk.
    125 amp fuse in this wire near battery.
    8 gauge wiring from 250 watt mono amp to distribution block with 50 amp fuse.
    8 gauge wiring from 120 watt 4 channel amp to distribution block with 50 amp fuse.
    Computer power wire to......????
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Slovakia
    how long will be wire from block to amp?
    for carputer you need wire rated for at least 10A ( I am not familiar with awg sizes 'cause I'm from europe but I think 14awg will be enough )
    AE
    May 2006
    Calgary, Alberta
    The amps and computer will be in the trunk and I guess I can put the distribution block anywhere it needs to be. I was thinking about the trunk to cut down on the length of wire from the amps to block.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Slovakia
    so once again
    if your wires from distr. block is short enough (about 2feet) , apms and PSU has its own fuse, so you don't need any other fuses put to wire.
    AE
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. Distribution Block Questions
    By beckkl in forum Power Supplies
    Last Post: 10-20-2004, 12:29 PM
  3. Power Supply Connections
    By nick9871 in forum Power Supplies
    Last Post: 07-12-2004, 07:25 PM
  4. quick fuse question....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-23-2004, 11:54 PM
  5. Replies: 5
    Last Post: 01-08-2004, 12:38 AM
