12volts white (50A) + ignition harness
Ignition black/yellow + ignition harness
Parking Lights+ red/black + top of fuse box, large white plug
Parking Lights- red/black - headlight switch in column cover
Headlight black/red or blue/red - headlight switch in column cover
Trunk/Hatch Release yellow/green + driver kick, harness to rear
Power Sliding Door N/A
Speed Sense blue/white ECM/PCM
Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26. On the 6 cylinder models it is in the gray connector A, pin 11.
Wipers green/white - windshield wiper switch
LF Window up/dn red/black - red/yellow A LF window switch in door
RF Window up/dn red/blue - red A RF window switch in door
LR Window up/dn red/white - blue/black A LR window switch in door
RR Window up/dn red/white - blue/black A RR window switch in door
Sun Roof open/close green/yellow - green/black A moonroof motor, rear of roof
Notes: This is only on the sedans. On the coupes the moonroof motor is integrated into the moonroof control unit not allowing access to the motor wires.
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays: Not Available
LinkBack URL
About LinkBacks
