Results 1 to 10 of 13
Thread: How to connect my CarPC to my sound system
    Jun 2006
    Ok, well I will be buying/building a car PC in the near feature. One of the things I will be purchasing is a Lilliput 7" In-Dash Motorized Touchscreen found here - http://www.mp3car.com/store/product_...roducts_id=206 -
    I want to know how it would be possible to connect my computer VIA the VGA adapter + USB (for touchscreen capabilities) and also connect the sound through this. Would I have to purchase an amp? Would it be more beneficial to buy an external screen and mount it somwhere else and just buy a new head unit to go through?
    I am very very new to car components in general and this is the one part that really has me confused as far as how to hook things up.
    Falls Church, VA
    At the top of every subsection is a list of FAQs... what you have asked is covered in these faqs. Due to this, you will get quite a bit of neative responses. There is also a search function. You may want to explore it.
    This forum is a resource for research, but not a hand holding service. We expect the new users to do a little work before we generally respond.
    I see your new so please dont take this offensively. So far you got off easy.
    Low Bitrate snoopdan's Avatar
    Aug 2005
    Louisville, KY
    Hey Will, maybe if there were less dickheads like you this fourm would be more helpfull ??
    MECA Car Audio Judge
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    Sorry, someone had to do it!
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    Elsewhere
    Quote Originally Posted by snoopdan
    For the name-calling you can have three days off.
    If there were less people calling users names, the forum would be a lot more firendly, too.
    A lot of forum members have invested a lot of time and effort to compile information for newbies. frank112916, this thread is an excellent place to start reading & learning: New to CarPCs? Don't know where to start?
    Welcome to our hobby.
    How about the Wiki?
    Jun 2004
    Rochester
    frank:
    Yes you can you this unit for you audio.
    It has an internal amplifier so you would not need to purchase one. You will, however, need to gain access to the wires that go to your car speakers. These are almost always available in the dashboard where your current car stereo plugs in. You can usually buy a handy adapter harness that plugs in place of your car stereo and gives you direct and easy access to the required speaker and power wires. Depending on your car, it can get a lot more complicated than that.
    Alternatively, you can choose not to use the lilliput for your audio. Perhaps if you are in love with your current car stereo, or maybe your current stereo has much higher audio quality.
    You might be able to get more specific answers if you let us know exactly what kind of car it is.
    I hope this helps, Good Luck.
    Jun 2006
    Quote Originally Posted by walky_talky20
    frank:
    Thanks alot, and it's a 2002 Dodge Neon.
    The thing is, the only inputs are for the speakers, a VGA input, USB for touchscreen, and 2x RCA (which includes a video source). Now I was going to just get a 3.5mm M to RCA but if I use this...I might have to turn to auxillary sound which might switch to AUX video also, but I want it specifically from the VGA w/ the AUX sound. That's my problem solved if turning it to AUX still keeps the VGA input on.
    I'm sorry about this thread guys, I was looking through the faq and I guess I just didn't look hard enough. And the first poster wasn't being a dick, he's just tellin the truth.
    Elsewhere
    Quote Originally Posted by frank112916
    Don't be sorry, man.
    Most newbies don't realize the depth of the information in the FAQs here. Also, It's refreshing to see a newbie that doesn't get offended when the get shown where to find the correct information.
    We're all librarians pointing newbies toward the card catalog.
    No matter what your project goals are, there are some ways to make it go smoother:
    1) Plan thoroughly. Plan everything from component purchases to wiring to audio upgrades to fabrication. Keeping a worklong here s a convenient way to keep track of your plan as it changes... And it will change along the way.
    2) The FAQ Emporium is a great source of information, as you've been told already. The Show Off Your Project forum is a great source of inspiration and ideas, as well. I haven't encountered a member yet who isn't willing to discuss their setup, pros & cons, and what pitfalls to avoid.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    Do NOT go out and buy all of the products that you *think* you need after only having read a week worth of stuff on these boards.
    TAKE your time! And welcome!
    Jan Bennett
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by Red GTi VR6
    I kept on making that mistake and jumping the gun....i ended up replacing everything i had originally bought and not using most of it.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. connecting carpc to audio system
    By ArcticGenes in forum Car Audio
    Last Post: 07-31-2005, 08:15 PM
  2. How do you guys connect your sound?
    By nsmoller in forum Car Audio
    Last Post: 03-05-2005, 02:40 AM
  3. How to send sound to headunit? or system?
    By SilverGT in forum Car Audio
    Last Post: 09-24-2004, 11:41 PM
  4. Carpc Operating System?
    By chuckctv in forum Software & Software Development
    Last Post: 09-13-2004, 10:47 PM
  5. How do you get sound in to your system???
    By DaPyro in forum General Hardware Discussion
    Last Post: 02-28-2000, 01:10 AM
