Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: amp keeps on blowing fuses
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Unhappy amp keeps on blowing fuses
    I finished my carputer install yesturday, and I've got a problem with my sub amp. The amp has blown its second fuse in basically one day. First time it blew the fuse I was trying to lower the gain because I felt that it hit too hard for the volume. The second time it blew when I turned the carputer off. The wiring is new, and there aren't any shorts that I know off, since its been blowing the fuses when I was still stationary.
    Any ideas on how to solve the problem would be great
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    If it works and then blows fuses and you said you have no shorts, there is something wrong with the amp internally.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by kickercivic1
    Any chance that the gain or something is set too high?
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Doubtful.. you'd probably have to have it cranked all the way (or more) to accomplish that.
    Also, what fuse? The one that's installed by the battery, or the one physically on the amp? What kind of amp and how is it hooked up with the speakers? What are the fuses rated on the amp if those are blowing?
    Jul 2004
    Berkeley, CA
    Well... it does hit a bit too hard for 35% volume. That's why I wanted to turn it down a bit, and then the first fuse blew.
    I am talking about the fuse on the acutal amp. I've got a 60 amp fuse right next to the battery, and then 3 30amp fuses going to each component (sub amp, 4 channel speaker amp, carputer). This amp has a 20 amp fuse.
    How is it hooked up? I bridged it (its a bridgeable amp), and it goes to the stock sub.
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Have you run down every line (power, ground, AND remote) to make sure??
    There was a short in my remote line for one of my amps which caused the fuse to blow...
    Also, what is the amp rated for...is 20A what originally came with it. (I do NOT suggest throwing in a 30 or something just to see if it works that would DEFINATLY hurt the amp.....) but if it is supposed to have a 30 and there is a 20 that would cause it to blow for sure (i know it sounds stupid...but hey you never know...)
    Brown 2010
    Jul 2004
    Berkeley, CA
    The amp is a Kicker IX402. Specs. Manual.
    Manual says 20a.
    How do I know that there aren't any shorts... because it worked when I was driving. The remote is connected between two of my amps (actually, it goes into the speaker amp, and a wire from the speaker amp goes into this one). So that's not the problem.
    Mar 2006
    NJ/RI
    The best way to check for a short is to actually run along the wire and see if theres a break in the coating anywhere....
    if manual says 20A then it should be right....
    Brown 2010
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Sidewalksalvage
    I know. I made sure already
    Jul 2004
    Berkeley, CA
    Oh yeh... and I used 8Ga wire. 4Ga from battery to distribution block, and then 8Ga to everything else.
    Another question... should I have it set to 70 or 110 Hz?
  1. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  2. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
  3. low amp fuse blowing in MX radio adaptor
    By march09 in forum Car Audio
    Last Post: 01-06-2006, 06:53 PM
  4. Blowing amp fuses!!!
    By capricedaddy21 in forum Car Audio
    Last Post: 07-29-2005, 02:58 PM
