Results 11 to 20 of 22
Thread: HUs with detachable face for remote mounting
  1. #11
    Jun 2006
    Still working on my car right now, but heres a preview on what the detachable hu looks like.
  2. #12
    Constant Bitrate munkynpunky's Avatar
    Oct 2005
    Norwich UK
    hi guys,
    I have a Pioneer P6400R and would like to have this done, but i cannot solder.
    I live in the UK in Norfolk, does anyone live nearby or can anyone offer any help. I already had a go and it took me 5 hours to remove the solder. The head unit is working again now, but needs soldering cat5 cables. i have the cables and coupler too.
    07979 42 46 27 - Drew
    Car is Dead, Hand is burnt - Let that be a lesson to me! never open the bonnet when you smell burning.
    http://www.digital-car.co.uk
  3. #13
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    soldering isnt that difficult really, as long as you have a good thin tip, and make sure not to keep the soldering iron on the surface for too long you should be fine (and yes, tinning both sides helps a LOT) touch both together, then touch with the soldering iron, remove soldering iron
    done!
    dunno why a lot of people have problems with it, its not that hard :T
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    soldering is cake, it's no excuse to say you don't know how to solder....give it a try at least!!!
    Jan Bennett
  5. #15
    Oct 2005
    Norwich UK
    Hey Guys,
    I did give it a try and a managed to screw it up and it took ages to reclean all of the solder so the screen would work again.
    Just looking for someone to help that was all.
    I'll keep looking.
  6. #16
    Newbie Timecloud's Avatar
    Jul 2006
    Hey, I'm a newb here but here is my input. I understand what your saying, your not good at soldering, but don't try on your HU the first time. although you did already.. but anyway, get some scrap wire and try again. It will come to you. Remeber to wipe the tip of the solder gun with a damp sponge after each attempt it will keep it clean.
    HTH
  7. #17
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    true that yo
  8. #18
    Constant Bitrate dvsmex's Avatar
    Mar 2006
    Anyone have pic's of the solder jobs?
  9. #19
    Constant Bitrate fooshizn1x's Avatar
    May 2005
    714 - Socal baby!
    Heres a little intro to soldering for those that are solder challenged, I agree its really simple when you know what your doing, but until then, its not the easiest thing to do.
    ***Your materials and iron will dictate the difficulty of the job almost all the time!!***
    i.e. if your using a crappy rat shack $5 iron you will not be able to solder very well after the first few uses, regardless of how good you are. You can still solder w/ it, but it makes it difficult.
    Buy a good iron.. I own a hakko 936-12 it was about $80 bux shipped. While this may seem steep to some, I do a lot of soldering, and it was WAAAAY worth it, I dont know how I went through life without it.
    #1 always keep your irons tip clean.. you cant solder well w/ a dirty tip
    #2 always use flux
    #3 always use rosin core solder (unless otherwise needed)
    #4 dont use more solder than necessary, its always easier to add then to remove
    #5 dont use more heat than necessary (i.e. a 90/140 watt gun is WAAAY too much for general home usage on small electronics.. 40/60 selectable, or complete temp slectable is best)
    How to solder:
    Strip wire, dip in flux, put solder onto tip of iron and melt a little to the tip of the iron, remove, then touch the iron to the wire w/ the flux on it. You will see the solder magically cover the wire (assuming your using like 16 and up ga) larger wires may require more solder or a second appliation. This is called TINNING the wire. Do this to both wires, or both surfaces to solder to. If soldering to a smooth surface you may want to use some sand paper to rough up the surface for the solder to stick. Once both wires have been tinned, I like to use a little more flux on one of the wires, and depending on what your soldering, sometimes a tiny bit more solder on the tip of the iron, hold the wires together, then touch the iron to the two tipped wires, it should heat it and solder them together, remove the iron and let the solder cool for a second (its almost instantly) you should have a nice shiney solder joint, if its dull that generally means its not a good connection (but not always) give the two wires a tug to make sure its solid, sit back, inhale the fumes and admire your work
    This may or may not be the most exact science way to solder, but its how I do it, and I've been soldering for probably 10 years.. started off with big boogers that fell off.. and now can solder SMTs
    ***If you need to remove solder from a surface I personally like to use braided copper wick, its cheap, I recommend everybody that solders to have some.. you just make sure your solder tip is clean, put a little flux on the wick, place the wick on top of the surface you want to remove solder from, apply heat for a second or so, you should see the solder melt into the wick, then lift it off.***
    When you are soldering small components its good to use a heatsink to divert the heat so you dont fry the component, but I'd assume if your soldering stuff that small you already know this.
    For a good intro into soldering pickup a few small kits from www.ramseyelectronics.com they've got tons of neat crap you can build
    good luck
    Sell me your stuff.. please see what i'm looking to buy
    http://mp3car.com/vbulletin/showthread.php?t=75182
  10. #20
    _
    Mar 2004
    Little Elm, Texas
    though it deals with wire termination, it's still close in concept
    FAQ: Proper Wire Termination and Connection Methods
    many good links in there for ya
    Jan Bennett
  1. extending detachable face from deck
    By cs91385 in forum Input Devices
    Last Post: 06-25-2006, 03:27 PM
  2. Just had a great idea for using a detachable cd players face
    By Gemini in forum General Hardware Discussion
    Last Post: 05-13-2004, 01:15 PM
  3. Detachable face as remote control
    By cruzc_99 in forum Off Topic
    Last Post: 10-11-2002, 09:02 PM
