Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: HUs with detachable face for remote mounting
    _
    Mar 2004
    Little Elm, Texas
    For those of you who have successfully been able to remote mount your detachable face head units, can you list them here in this thread and also mention any issues or concerns that you ran into?
    I think this would be a good resource to those looking to do the same thing.
    Jan Bennett
    Variable Bitrate DaveB's Avatar
    Mar 2004
    Pioneer DEH-P6400
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Jun 2006
    Today I bought a brand new Alpine CDA-9856.
    I tried the remote mounting it worked great. Everything functioned correctly. I used 3 ft cat6 cable soldered at each end and then used a connector to connect them together. Took about 2 hours. I was talking to one of the guys at the stereo shop and they told me that this should work on ALL alpines. I think the people who had trouble doing it weren't connecting it correctly. I will be doing another one soon on a new pioneer so i'll post my results when im done.
    Mar 2004
    Congratulations on your project! I'm glad it worked for you!
    I'd say it worked for you because of the 3 foot cable. I doubt that would be long enough for most people if they want to mount the faceplate on their sunvisor. My cable was closer to 10 feet. Its the low power and the cable distance that make it so that it doesn't work with most head units.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Jun 2006
    im not so sure i buy the long cable theory. cable resistance should only matter if the faceplate was drawing high current. The dude at the stereo shop said he did it in a lot of boats and the cables were over 20 feet long. But who knows. I think the most important thing is how well your soldering job is and how well you can secure the cable so it doesnt come off. i'll post some pics when im done with my whole project.
    _
    Mar 2004
    Little Elm, Texas
    cat 5 over long distances and other wire over long distances are different stories.
    Jan Bennett
    Mar 2006
    Colorado, but Canadian!
    Even if it was a power thing, couldn't you just wire up some simple transistors to a power supply, and then use that to boost it? They should be ample fast for data streams as well? Could a simple solution work?
    1.9in x 2.9in -- 47mm x 73mm
    _
    Mar 2004
    Little Elm, Texas
    there really shouldn't be any current on a face plate. Everything on a face plate is very low current, leds and switch points, etc.
    The biggest issue is the solder joint, since Cat 5 is solid, making the connection will be difficult.
    But, it can be done!
    Jan Bennett
    Jun 2006
    yeah, i did my soldering on an expensive metcal soldering workstation from my work. I used the thinnest tip to do it. Tint the gold connectors first, tint the ends of the wires, and then just touch them and solder, very easy. But if you using one of those big tipped radio shack soldering irons, then the job is definitely more challenging.
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    anybody have pictures? i want to see this
  1. extending detachable face from deck
    By cs91385 in forum Input Devices
    Last Post: 06-25-2006, 03:27 PM
  2. Just had a great idea for using a detachable cd players face
    By Gemini in forum General Hardware Discussion
    Last Post: 05-13-2004, 01:15 PM
  3. Detachable face as remote control
    By cruzc_99 in forum Off Topic
    Last Post: 10-11-2002, 09:02 PM
