Geez...that 4 gauge wire is about $6 per foot, if my conversion is correct! Things really are expensive in England...Originally Posted by Will Albers
Originally Posted by Tim Lake
Perfect! and even a little overkill. But thats what we want.
- Monthly North Texas Meet thread
- My worklog
- gDrive Install pics
- How to add your CarPC specs to your username
An amateur built the Ark. The Titanic was built by professionals.
Tell me about it!
I spent nearly £50 ($90) on wires when I set the system up originally!
Is it possible the amp is faulty/crappy though, it's not the best (it's a Maystar, never heard of them) and I am tempted to replace it anyway. I'll do as we've decided tomorrow and see what happens but if I still get noise I'm buying a new amp!
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
Its a possibility. You will be an expert at the end of this
Ha ha, very true.
Thansk for all your help, I really appreciate it.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Well I did as planned.
I ran the carnetix unit and head unit to the battery negative and the active crossover and two amps through a distribution block to a solid ground on the floor pan.
It still makes the same amount of noise
Incidentally, when I mute the head unit the noise is quite a bit less but still bad! What the hell is that about!
Help me, i'm on the verge of buying a new amp but I want to know if there is anything else I need to try first so I don't waste my money.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Well I have gone and done it.
I ordered this:
http://caraudiosecurity.com/shop/pro...s_id/2608.html
£65 down from £110 so it's a good price for a good amount of power. I just hope it cures my problem otherwise I'm screwed!
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Actually, that's a horrible amp. The problem's more than likely still going to be there.
Tell me that's a joke
I thought I'd done well there!
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Stay away from any car audio that says Sony or Xplod on it. It's all garbage. Everything they made after their Mobile ES line is utter crap except for their tray-loading CD players.
