Page 1 of 7 1234567 LastLast
Results 1 to 10 of 66
Thread: Sound deadening, liquid vs mats
    Sep 2005
    So i'm thinking about sound deadening my matrix a little bit...the car has practically no sound deadening in it what so ever. I'm debating between using this liquid stuff called quiet car or getting 2 rolls of Raam mat. The advantage of the liquid is that it's lighter, but I'm not sure how well it will work. The advantage to the mats is that you only need 1 layer most everywhere and it's not as hard to install, but they weight more.
    Someone help me chose here...I'm hoping to not add to much weight into the car, but I want some of this road noise gone. Not all of it, just a good bit of it.
    Maybe i'm thinking into this to much, how much does 1 roll of the sound deadening mat really weigh? I'm guessing like 50lbs for a roll...but I could be off.
    Constant Bitrate reiner15's Avatar
    Mar 2005
    Michigan
    Quote Originally Posted by Slightly_Stoopi
    Depends on where you want to deaden the sound. liquid might be better in some places where as mats may do just fine in others. I recommend secondskinaudio.com - they have some forums on there and the owner is extremly helpful when making purchases. Plus, if you join the forum, you will be eligible for a discount.
    My Site: http://www.reinerweb.us
    My Car : http://members.cardomain.com/reiner15
    Car Computer Alias - TekPC
    Current Progress - - Brainstorming
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Well, part of how sound deadening works is the weight. More mass means higher damping, meaning less vibration. Besides, two rolls of raammat is less than 50 lbs. If the liquid stuff is half of that, I don't think you'll notice an extra 25 lbs when comparing the two unless you compete in SCCA or something.
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Jul 2001
    I used RAAMMat in my other car. Good stuff. A combination of liquid in open cavities(pillars and stuff) and mat works best.
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    My 100sqft roll of fatmat weighed under 25lbs and did a great job with just one layer. The asphalt based stuff like dynamat original is a lot heavier.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
    Low Bitrate tasteItheIvalue's Avatar
    Nov 2005
    Connecicut; United States
    i used a 100sq ft roll of the asphalt **** in my subaru impreza. weighs a bunch but does a hell of a job. the before and after are amazing. there is not one bit of rattle coming from my trunk now; before the rattling made it sound like dog ****.
    _
    Mar 2004
    Little Elm, Texas
    read these few links for some help:
    how to apply: http://www.partsexpress.com/tech/268-010.html
    sound deadener showdown: http://www.sounddeadenershowdown.com/
    Jan Bennett
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    Quote Originally Posted by Red GTi VR6
    wow, thanks for links GTI
    Yev
    R. T. F. M
    _
    Mar 2004
    Little Elm, Texas
    np - good luck!
    Jan Bennett
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    BTW, instead of buying expensive mats. Go to Home Depot or Lowes and pick up Seel-n-Peel or Jiffy Seal (I use Jiffy Seals, it's heavier, cheaper and stickier). I did my doors with it... for $15 I made my car much quieter than stock. Time to do the trunk, floor and ceiling!
  1. Sound Card discussion, 4.1, sound quality, need help
    By jedi7001 in forum General Hardware Discussion
    Last Post: 05-19-2005, 10:47 AM
  2. Pro Logic vs digital surround sound
    By lookinco in forum Car Audio
    Last Post: 08-28-2004, 10:29 AM
  3. Sound Quality with External USB Soundcard
    By nirvanades in forum General Hardware Discussion
    Last Post: 08-12-2004, 06:34 PM
  4. alright, sound distortion from over boosting.
    By ares in forum General Hardware Discussion
    Last Post: 03-14-2004, 01:04 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
