What motherboard/cpu and what power supply are you using?Originally Posted by psptibby
And hey... if the PSU can't supply enough, you can always get a opus point of load psu just for that line.
I have gps and the touchscreen, hard drive. And then the cdrom will be attached usb. Then i am adding a usb card, oh and bluetooth. The 2nd hub will be for user port availble to driver or passenger in the car as well as a memory card reader.
Do you think that is too much? Most of the is low powered devices.
its the via 1.2ghz board witht the m1-atx 90w ps.
What is the opus piont of load?
check this:
http://www.opussolutions.com/index.php?p=product&id=24
Prepping for Trax in september
Re-Building the whole CarPC to upgrade all the software
Whole new boot build and moulding my screen into the dash...Again
Interesting. So that is a serperate psu for devices? That would be wired to the battery?
