Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
Thread: Replacing 2000 Suburban factory radio
  1. #11
    Jul 2001
    Did you check your door locks when you had the radio unplugged?
    I was thinking 03-up on the expensive harness. You should be good with that 70-1858. Do your speaker grilles say Bose on them?
  2. #12
    Jul 2006
    Nope. No Bose anywhere. Thanks for the advice
  3. #13
    Jul 2006
    Radio Intsall Update
    Gentlemen (and ladies),
    Thought I'd wrap this up for anyone who runs into the same situation.
    Synopsis
    2000 - 2003 GM was in transition with the radio/On-Star/operator notification systems. During that time you could have any of the following combos depending on the model/year (I believe they all had On-Star):
    No Bose/No RDS/No Class 2
    No Bose/RDS/No Class 2
    No Bose/Class 2
    Bose/RDS/No Class 2
    Bose/No RDS/Class 2
    Their may be other combos as well. The Class 2 interface really complicated things by including driver notification (chimes) in the radio system as well.
    Back to my setup (On-Star/No Bose/No RDS/No Class 2) 2000 Suburban.
    If you have a vehicle with this setup and you want to keep On-Star working you must get a PAC OS-1 interface device (or equivalent) ~$100. Scosche and Precision VAR this device as well. I went this route and it works perfectly.
    If you don't care about On-Star and don't want to drop the coin on the PAC OS-1 you'll have to play with the wiring a bit. The radio has two connectors. The larger (21 Pin) is your standard radio connector. The 18 Pin is the interface to On-Star and any other sub-systems. You will need to tie one or more wires on the 18 Pin to a suitable trigger to activate the factory amp. See the wiring diagram attached above for more details.
    If you have a Class 2 radio you will need the PAC OS-2 (or equivalent) along with the chime module.
  4. #14
    Jul 2001
    Hey, at least you learned a thing or two about your truck Most people just want to be spoonfed as soon as they hit a snag but those people usually don't have hobbies like this.
  5. #15
    Jul 2006
    The saga continues
    I installed PAC OS-1 and On-Star and the radio now work. That's the good news. The bad news is that only the front speakers will play. I know it's not the radio because I connected the front outputs to the rear speaker leads and nothing, but they work when connected to the front speakers.
    Any ideas?
  6. #16
    Jul 2001
    There's an amp somewhere that's not getting turned on.
  7. #17
    Jul 2006
    Looking at the wiring diagram there's just one amp for all the speakers and the fronts are working. I may end up bypassing the amp for the rears. What a PITA this has become just to replace the factory radio.
  8. #18
    Jul 2006
    Any ideas where the physical location of the amplifier in the suburban is?
  9. #19
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by saraja
    Any ideas for the physical location of the amplifier?
    Under one of the seats in the second row.
    TruckinMP3
    Read the FAQ!
  10. #20
    Jul 2001
    I bet it's in the center console.
  1. 2000 mitsubishi eclipse factory display lcd
    By uhhwtf in forum LCD/Display
    Last Post: 06-27-2006, 07:55 PM
  2. how u remove the radio from 2000 civic
    By bluehcc in forum Car Audio
    Last Post: 04-11-2006, 11:02 AM
  3. Keeping Factory Radio (but not using it except FM)?
    By dummptyhummpty in forum Car Audio
    Last Post: 03-21-2006, 12:56 PM
  4. Installing computer w/ 2000 GM factory stereo-how to connect
    By SpkTheD in forum General Hardware Discussion
    Last Post: 05-09-2005, 09:05 PM
  5. TM-701L converted Lilliput causes radio interference
    By archimense in forum LCD/Display
    Last Post: 07-04-2004, 09:14 AM
