Wow, this topic has been all over the place.
I just want to verify something before I cut anymore wires because there's been some conflicting posts. This is my 4x4 and we're in the middle of ANOTHER blizzard, so I want to work on it while I'm snowed in, but not have a lot of down time because I snipped the wrong wire. I need the car even if I just use the old
radio.
Mine is a 2001 Suburban. It has OnStar, but obviously it doesn't work anymore anyway and I never paid for it, so I don't care about it. As far as I can tell, it is a "Performance Enhanced"
sound system, but it's not Bose. I think it's just got upgraded speakers. It's pretty hard to get a straight answer even from the RPO codes. I don't THINK it's got an
amplifier. I don't know how I'd know and frankly, I don't care about it. I'd just as soon bypass it. I do NOT have rear speaker controls (other than the standard balance/fade on the radio).
Anyway, the factory stereo does have two harnesses. The "standard" harness and a second one (smaller and REALLY short, so it's hard to work with). I've used the Scosche harness for the standard GM wires, so up to this point I haven't cut anything.
When I plugged in the new Pioneer Premier, everything lit up and worked except I had no audio from anywhere. So, I went back to the factory stereo. I noticed that I still had no audio until I plugged in the second little short harness, so I know I need to somehow bypass that. I keep hearing about a bypass harness to just skip OnStar and the factory amp, but I can't find one.
If I'm reading this correct, I just need to snip the pink wire on the second harness and wire it into the blue/white remote wire coming from the Pioneer. So, I'd have two wires, one from each harness, going to the one blue wire.
That bypasses the OnStar and amp, and just gives me the stereo I bought with all 8 speakers? Correct? This has been tested?
That makes it seem pretty simple, but there are like hundreds of posts around the web from "it can't be done" to ripping out all the old and replacing all the
wiring.
Thanks for your patience with me. I'm slow and cautious before I start cutting wires I can't reach to repair.
