Results 11 to 20 of 30
Thread: Amp Shuts Off
  1. #11
    Jul 2001
    Not necessarily blue, but usually.
    4-ohm stereo impedance
    What? Is it a dual-voice coil speaker? If so, there's your problem.
  2. #12
    Jul 2006
    Southern California
    Yeah I just researched my subs and they are dual voice coil subs. Is that a problem? If so how do I remedy it?
  3. #13
    May 2006
    San Jose, CA
    If the spearkers have 4 ohm Dual Voice coils and you are wiring them in parallel then you are running at 2 ohms. This is probably putting your amp into protection mode. Check out the link below.
    To remedy the problem you might need to upgrade to a amp that can run 2 ohm stable or even 1 ohm stable.
    http://www.rockfordfosgate.com/rftec...l+-+4+ohms+x+2
    Anyone else see this as his issue?
  4. #14
    Jul 2001
    Quote Originally Posted by ergman
    Quote Originally Posted by shadow four posts above yours
    Underimpedance.
    Your amp can't handle the load you're trying to put on it.
    Remedy steps:
    1. Get rid of that amp
    2. Get a two-channel amp that's stout enough to push both of your woofers and you can either run them at 2 ohm stereo (parallel the coils on the subs and connect one to each channel) or 4 ohm mono (run the coils on the subs in series and parallel the subs to one another to the bridge input on the amp). The first setup's probably easiest for someone who's not too keen on impedance and wiring.
  5. #15
    Jul 2006
    Southern California
    Okay so I am willing to buy a new amp that will run my subs at a 2 ohm load. I want to be able to push my subs pretty hard so are their any recomendations for wattage and RMS? Specific brands?
    Also why did it take my system so long to start having problems? It went about....at least 7 months with no problems.
  6. #16
    Jul 2001
    Electrical components will stress themselves until they fail. Obviously yours took 7 months. You never posted a model number for your subwoofers.
  7. #17
    Jul 2006
    Southern California
    My subwoofers model number is Audiobahn ABB102Q.
  8. #18
    Jul 2006
    Southern California
    Do I need to get an amp that can give each sub 4 ohm's? That is what it seems like.
    http://www.crutchfield.com/S-WtpneEE...p?I=037ABB102Q
    subs
    http://www.lanzar.com/itempage.asp?MODEL=VIBE420
    Amp
  9. #19
    Jul 2001
    I can't find any specs that tell what those subs are rated in plain non-crappy english so I can't help you any more. Everywhere says 4 ohm stereo but doesn't say whether or not the subs are DVCs or what so I'm afraid I'm done helping. Find someone near you that knows what they're doing so they can actually put a meter on the subs and figure out what's happening.
  10. #20
    May 2006
    San Jose, CA
    Well, Depending on your budget you can get the Alpine PDX series amps. I have the 4 channel PDX amp and it kicks ***. You can get the mono PDX amp to power your subs no problem.
    check them out at the alpine website.
    http://www.alpine-usa.com/en/product...p?category=AMP
    You can find them on ebay for a it cheaper than the MSRP on the alpine site.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  3. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
  4. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
