Results 1 to 7 of 7
Thread: Which DAC ?
    Apr 2006
    Which DAC ?
    Hi well after a lot of reading i decide i will go with USB-DAC
    and i found this ones
    Silverstone EB01
    http://www.silverstonetek.com/products-eb01.htm
    Maya EX7
    http://www.audiotrak.net/mayaex7.htm
    and the Gigaport AG
    http://www.esi-pro.com/viewProduct.php?pid=12&page=1
    My system will have this EQ . (alpine 3321) http://fukuhara.com/fukuhara/derek/c...21/default.htm. and 2 amps(1 amp 4ch. and the other a class D)
    Which one would be better suit for my needs ?
    Thanks in advance
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    only the silverstone is a dac, the others are usb soundcards
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Buy my silverstone EB01 dac. I want to upgraded min.
    Dec 2004
    Los Angeles Ca
    what are you upgrading yours too?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2003
    Florida
    I want to get something that has rear, front and Sub output built in.
    Apr 2006
    Quote Originally Posted by scott_fx
    Scott.......> i though all of those were DAC. in this case what would be the difference between those. ? or which one of those is the one i need ? i will run just 2 amps.
    if you can give me a link or post some pro's and con's between those pls.
    kickercivic1....> How much you want ?
    Thank you
    Dec 2004
    Los Angeles Ca
    well, even soundcards have dac's in them but the usb dac's sole purpose is the conversion (as i understand it). Generally the output is more dynamic and cleaner.
    the usb dac's will be seen as a usb speaker, hence no additional driver is needed. the usb dac's are usually only 2 chan. though and you'll need an active x-over if you amps dont have internal x-overs and pre-outs. I don't have any links off hand but if you do a search you can read a lot of the reviews about the dacs and how they are generally much cleaner then soundcards. The silverstone is an entry level dac but for the price it's a great unit (based on the reviews i've read). You can do some searches for diy dac's and what not if you want better components and are willing to spend a little more
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Routing audio from Line-in to usb DAC
    By Preston Masters in forum Car Audio
    Last Post: 10-07-2009, 03:57 AM
  2. Car Computer and external DAC
    By General_Tux in forum Car Audio
    Last Post: 05-01-2006, 10:02 PM
  3. MacMini and DAC
    By General_Tux in forum MacCar
    Last Post: 05-01-2006, 12:25 PM
  4. External DAC vs No External DAC
    By rowen in forum Car Audio
    Last Post: 05-18-2005, 11:23 AM
  5. Good 12v DAC?
    By ErikGreen in forum General Hardware Discussion
    Last Post: 09-09-2004, 01:55 PM
