Results 1 to 8 of 8
Thread: Advice on AMP
    Newbie donniesd's Avatar
    Jul 2006
    H-TOWN
    Advice on AMP
    I have aquired 2 JL Audio W3v2-D2, and have each sub wired in parallel "mode". So each sub is at 1.0 Ω. I have a Audiobahn A8002T Amp now, but its not stable.
    I do have a ported box. So any one with ideas on a good amp. Please do tell.
    I have looked at a JL 500/1, but that will not give these bad boys a good run...
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    EACH sub is at 1 Ohm? I don't know if you'll find many, if any, 2 channel amps that'll run in 2x1Ohm mode, most will bridge down to 1 Ohm, or if a mono-block, will run in 1 Ohm.
    I'm guessing they're dual voice coil at 2Ohm per coil? You may want to wire them together in series and parallel so you can get a 2 Ohm rating across both subs, then find a Monoblock amplifier that will run 2 Ohm at the wattage you want.
    Jul 2006
    H-TOWN
    Quote Originally Posted by Jahntassa
    Your on the same wavelength as me right now. Doing more research, thats what i have come to find.
    Jul 2001
    You need a mono amp that can handle a 2 ohm load by wiring your subs in series to one another.
    You could also wire the subwoofer's coils in series to produce a 4 ohm load and then parallel the speakers to get a single 2 ohm load.
    Jul 2006
    H-TOWN
    Quote Originally Posted by Shadow
    How would i go about doing that?
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by donniesd
    Attachment 31364
    More info: Manual
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    elemental desings has a nice 1 ohm stable amp
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2006
    H-TOWN
    Quote Originally Posted by scott_fx
    Thanks bro. I will look at it.
  1. Amp Shuts Off
    By ElementXofXMusi in forum Car Audio
    Last Post: 07-18-2006, 08:34 PM
  2. AMP wont turn ON!! HEELP!
    By pdjafari in forum Car Audio
    Last Post: 10-15-2005, 08:43 PM
  3. PC to AMP - AMP to Speakers connection
    By craigt in forum Car Audio
    Last Post: 09-23-2005, 09:36 AM
  4. amp temperature
    By modh1984 in forum Car Audio
    Last Post: 06-13-2005, 11:24 PM
  5. Powering Carputer and amp ...
    By TxMazda3 in forum Newbie
    Last Post: 06-03-2005, 04:12 AM
