Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 119
Thread: Stuck an confused !!!
  1. #21
    306
    306 is offline
    Newbie 306's Avatar
    Jul 2006
    Blaenavon
    Quote Originally Posted by Red GTi VR6
    can you answer this?
    30
    Head unit - Pioneer - DEH-P6400R
    Speakers - componant sets up front, 2x mutant 2way in rear.
    Amps - 2x 500w
    Subs - 2x 12" 500w 50oz
    90% dun.. need screen :~
  2. #22
    306
    306 is offline
    Newbie 306's Avatar
    Jul 2006
    Blaenavon
    btw - can you tell me (if there are any) what the fuses on the side of the amp say?
    Yea theres a 30A
    an the amp is runnin off a 4gauge stinger kit with a 100A inline fuse
    Amps - 2x 500w
  3. #23
    Jul 2001
    Assuming 100% efficiency, which that amp is NOWHERE near, probably 40-50% efficient, you're producing a MAX of 432W at 14.4V.
  4. #24
    _
    Mar 2004
    Little Elm, Texas
    30 amps x 12 volts x 70% efficiency (that's being extremely generous on that amp if it's not a class D) = 252 watts per amp (not per side, but per amp)
    no denying those numbers. There's no way you're getting 500 watts out of those amps, I even doubt that you would get 500 watts on a short burst.
    and 100A fusing?
    absolutely not doing a damn bit of good other than protecting the wire...but even then, it's not doing much good protecting a 4 gauge wire, you'd need around 2 gauge for a 100 amp fuse to be protecting the wire when we're talking about lengths in a car.
    30 amps x 2 amplifiers = 60 amps of fusing. You shouldn't have much more than 60 amps of fusing on that power line. (again, that's if you're running 2 of those amplifiers)
    By running a 100A fuse, you aren't protecting anything. HOWEVER, kudos on at least fusing the power wire!
    and scott, you're right, I'm just rather annoyed at newbies that seriously think their **** is right yet when you crunch the numbers, it doesn't even come close to what they are claiming. I'm just tired of running into it over and over again. I know it's not this guys fault, I just wish more people would do a bit of research before purchasing things. Lost of money being blown down the drain.
    Jan Bennett
  5. #25
    306
    306 is offline
    Newbie 306's Avatar
    Jul 2006
    Blaenavon
    30A x 12V = 360W... thats 180W per channel
    i didnt say i was getting 500W from them amps... just sayin thats wa they say on there... i didnt say i was gettin 500w out of them...
    and as for me avin cheap amps... i cant aford to spend 700 on a nice amp... and if i did i wouldnt have no windows left.. its only a little 306... i only want the amps to last for a while till i get the money to go powerfull..
    Amps - 2x 500w
  6. #26
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by 306
    you're assuming the amps are 100% efficient. Which is an incorrect assumption.
    hence my accounting for it inmy post 70% is a rather generous number too.
    that's fine, we were all there at one point in time. Buy you also don't have to spend $700 to get a good product. $200 would get you a nice amplifier! You're just falling into this thing where you see say, $100 for 500 watts, or $200 for 250 watts...if it were that simple I'd see why you made the choice you did, but it's not that simple, thus the reason I'm trying to tell you why it's not a good amp.
    Jan Bennett
  7. #27
    306
    306 is offline
    Newbie 306's Avatar
    Jul 2006
    Blaenavon
    the only reason i have them is coz i got them verycheap..
    im lookin to spend 100 pound on a amp... i was goin to go with kicker or rockford.. but there way to much money...
    im presuming it will sound better to have mached brands??? or not ??
    Amps - 2x 500w
  8. #28
    _
    Mar 2004
    Little Elm, Texas
    matched brands don't make a lick of difference in all reality.
    Jan Bennett
  9. #29
    306
    306 is offline
    Newbie 306's Avatar
    Jul 2006
    Blaenavon
    after dissing my ****te amps... wa u think of wats runin them ???
    JVC KD-G521
    Amps - 2x 500w
  10. #30
    _
    Mar 2004
    Little Elm, Texas
    in all honesty? I'm not the person to ask that.
    I have my own standards that I have set for myself. I have held myself to those standards and it has gotten me a long way.
    Jan Bennett
  1. Volume Stuck
    By B|ade in forum Road Runner
    Last Post: 06-28-2006, 11:04 AM
  2. Should I change or Let her go?....So Confused
    By BIzFlawless in forum Off Topic
    Last Post: 05-26-2006, 10:27 PM
  3. xenarc came today... confused
    By chrislloyd in forum LCD/Display
    Last Post: 04-04-2005, 09:01 PM
  4. Replies: 13
    Last Post: 06-06-2004, 07:40 PM
  5. Im confused...
    By gsand in forum Software & Software Development
    Last Post: 10-07-2003, 08:10 PM
