Why wouldn't it? You're not pulling any extra current by grounding everything better. Oh, don't forget to put a fuse between your battery and your alternator. You'll probably need to use ANL fuses.
I plan on doing this upgrade, but I don't think I have enough wire for the alt to battery positive right now. I have enough for neg. battery to chasis and engine to chasis. I want to go ahead and wire these 2 up today and the rest of my wires. Would it be a problem to my car/alternator if I didn't upgrade it while my system was operating? I'll have a carputer, 800 watt peak amp, 500 watt peak amp, audiocontrol xover, xm direct running off the distro if that helps! Thanks for any response!
I can't guarantee accuracy, but it came with my Audiobahn amp:
The rest could be found on their website. Choose Tech Tips.
Page 6 of 52.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
another few resources:
Hope this helps.
Also, you can never have too big of a ground wire. It never hurts to have a ground that's bigger than the power. Just a power that's bigger than a ground when the power is the size needed. Ground should be at least the same size of the power, never smaller.
Jan Bennett
