Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: sub wiring question
    Apr 2005
    Northern Virginia
    sub wiring question
    I've been asking a lot of questions on matching subs and amps lately, and I just want to clarify some questions i've had
    if i had an amp that outputs 600watts bridged @2 ohms...if i wire 2 4-ohm subs in parallel, to drop their impedance to 2 ohms...would i be able to wire them on the single channel thats bridged? and if so, does that mean each sub gets 600 watts? or is it half to each?
    _
    Mar 2004
    Little Elm, Texas
    all but the each sub getting 600 watts is correct.
    Jan Bennett
    Apr 2005
    Northern Virginia
    *sigh* I feel like i'm going around in circles with the sub/amp selection, but I appreciate your help with all my questions Red, Thank you, you've cleared up a lot of questions I have had, now I just have to apply what I've learned. Thank you again.
    _
    Mar 2004
    Little Elm, Texas
    you'll keep going around, just make your decision, and realize that this probably wont be the last time you make a purchase, just realize this and remember what you can for the next time.
    Jan Bennett
    Apr 2005
    Northern Virginia
    so if i have 2x 8-ohm subs (DVC)...i can wire them, to get a 2-ohm load, then get 600/2, so 300watts per sub?
    and a side question, are DVC's in the same series of subs usually higher quality (in general, i know there are always excpetions) in like the rockford/pioneer/alpine classes?
    _
    Mar 2004
    Little Elm, Texas
    no - you said 2 8 ohm subs in your first post....
    Quote Originally Posted by senseless228
    they are no different, they are only for different applications.
    Jan Bennett
    Apr 2005
    Northern Virginia
    sorry, yea i know they're different in the posts, the reason is, I was looking at rockford fosgates wiring wizard, and if i get 2x DVC 4-ohm, it only has 1ohm and 4 ohm applications, and I dont think my p6002 would be stable at 1-ohm, and 4 ohm would only give me 150x2, so i'm assuming if i get 2x DVC at 8-ohm, I can get it wired to 2-ohms, and thus getting the bridged 600watts, so 300w per sub...
    so I'm assuming my options for DVC subs are either 1x 4-ohm, so i can wire it to 2ohm and get 600watts for a single sub
    or
    2x 8-ohm, wire them to get 2ohm, and get 300watts each
    and a SVC, i could get 2x 2-ohm sub and get stereo 300watts each (300w x2 @2ohm), or 2x 4-ohm in parallel, and get the bridged for 300watts each again...
    i'm posting this here, cuz its easier for me to think it through when i'm typing it out, i'm just trying to verify my research and see if its accurate, because none of my friends or family know anything about car audio, and working at best buy, I know the installers aren't the most knowledgable either.
    _
    Mar 2004
    Little Elm, Texas
    600 watts at how many ohms?
    Jan Bennett
    Apr 2005
    Northern Virginia
    when bridged, its 600watts @ 2-ohms (rated) on my "birth sheet (actual rating)" its like 699watts, but i'm just gonna stick to 600 for the sake of my mental capacity.
    Apr 2005
    Northern Virginia
    wait, no...crap crap crap, its 4-ohms, i just double checked, *sigh* you're right...600 watts at 4-ohms bridged...
  1. M2-ATX wiring question - ignition override?
    By DaveB in forum Power Supplies
    Last Post: 03-03-2006, 05:15 PM
  2. '95 windstar amplifier wiring question
    By Vchat20 in forum Car Audio
    Last Post: 03-04-2005, 08:13 PM
  3. Specific Opus wiring question
    By rdc_3200 in forum Power Supplies
    Last Post: 07-24-2004, 05:12 PM
  4. Wiring question
    By barometer in forum Newbie
    Last Post: 07-14-2004, 06:35 PM
  5. Headless Setup - Quick Amp Wiring Question.
    By crosseye in forum Car Audio
    Last Post: 07-13-2004, 03:18 PM
