yeah comparing caps vs batteries is trying to compare coke vs pepsi
Pancit175 I agree. Arguable lol
my TURBO! Altezza!
ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
PROGRESS:
Which one is coke? I like coke better than pepsi
my TURBO! Altezza!
additional batteries will do more than additional caps...for less money.
caps are pretty much useless unless we're talking about the multi farad caps
Jan Bennett
I was thinking 100 Farad , If I put one Sub on one amp would this meen I get 2ohms aswell
my TURBO! Altezza!
if each sub is a 2ohm DVC sub, you can wire one of the subs up with the voice coils on that sub in parallel to get a sub that's at 1 ohm.
Since each amp is capable of 1 ohm, you can wire it up as such.
What's wrong with that?
Jan Bennett
How can you get a 100Farad cap for less than a battery?
Series parallel of those subs will yield 2 ohm mono.
Im confused is this what your talking about.
my TURBO! Altezza!
XXX Series: 12" Dual 2 Ohm standard is the sub. Shadow now you have confused me I want 1 ohm each sub each amp.
Ebay Has some cheep Capasitors
my TURBO! Altezza!
Originally Posted by Shadow
Well, this isn't 100 farads, but it is 40, which is aheck of a lot of capacitance. Not cheap, either, $330, but still a lot less expensive than caps used to be.
The necessity for a cap is something that could be debated, and I pretty much fall onto the side of not needing one, but hey, they look cool...
Dave
