Originally Posted by Philhop
he's saying you can wire each sub in series, then wire the two subs in parallel to get 2 ohms.
I'm saying you can run each sub wired to 1 ohm and put ONE sub on ONE amp to get 1250 watts per sub.
In this instance you would need one amp per sub. But if you're talking about running two amps anyways, it shouldn't be a bit deal.
btw - why do you need this much power, are you competing with it or is it essentially just a penis extension?
LinkBack URL
About LinkBacks
