yes I am, cheap, wavey, crappy ****Originally Posted by Philhop
if you're going to be running this much power, you need more juice to power it all.Originally Posted by Philhop
One battery will supply y current, two batteries will supply y X 2 current, provided the rest of your electrical system can keep up (ie. alternator and wiring).
If you're going to be demanding 1250 watts x 2 = 2500 watts you need the following
2500 watts / 12 volts = ~210 amps of current. Use this to determine battery size below:
and this for alternator size:
For fusing: those amps are probably a class D amps, meaning roughly 80% efficiency = 2000 real world watts / 12 volts = 167 amps of fusing total.
Use this for wire size:
and this for fusing:
Hope that helps.
Jan Bennett
Jan Bennett
there should be some sanctioning bodies over there that hold the car audio competitions. You might even have IASCA over there.Originally Posted by Philhop
The ones that Shadow mentioned are local to North America mostly.
Jan Bennett
That helps but confused the crap out of me lol Im just going to throw in some some stuff and hope it works . If I get problems Ill upgrade. Wavey wtf
http://homepages.ihug.co.nz/~timhop/...0complete.html
How can you call that wavey
my TURBO! Altezza!
ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
tsw wheels are not quality wheels. sorry.
the chrome on those is not of a high quality finish.
I also don't suggest just throwing stuff in there, crossing your finders and praying that it works. You will risk a rather large fire if you do that.
Jan Bennett
What ever another day Red. I have a 200amp circut breaker and im pulling 120a at the moment and im blowing the circut breaker perhaps its a faulty Breaker.
Thanks Red anyhow been a great help Im sure it will be impressive none the less even If you dont think so, Ive see the eyes roll and the drool form as I roll buy, Pehaps the ladies in New zealand have more taste than you, because it helps the hit rate lol!
Btw those mags are prototype before they even came out. Extra Care was done when making them I have a life time guarntee, Only New Zealand owner at this stage, and I assure you the crome is a high quality finish even if you must say they are not.
my TURBO! Altezza!
Have a look hereOriginally Posted by Philhop
It's your car, why should you care what I have to say?Originally Posted by Philhop
I haven't gotten to where I have by holding subpar standards. I stand by my standards, many times those same standards are seen by some as being elitest, to others, they see why
If that's all you're after, why not chrome your grill? (as in your teeth?)Ive see the eyes roll and the drool form as I roll buy, Pehaps the ladies in New zealand have more taste than you, because it helps the hit rate lol!
I've yet to see a TSW wheel that's of HIGH quality, of average quality, yes, high? not at all.Btw those mags are prototype before they even came out. Extra Care was done when making them I have a life time guarntee, Only New Zealand owner at this stage, and I assure you the crome is a high quality finish even if you must say they are not.
again, perceptions. What's high quality to you is different to others.
Jan Bennett
This is what I was thinking Any suggestions, Thanks meddler for that post ill look into it!
my TURBO! Altezza!
Seems Crazy Red that your kinda flaming me yet helping me interesting response I must say.
Reply to your other message is that no I dont care what you think, I do somewhat care what other think as what you should do to a degree, with out getting pig headed or arrogant, as people appreciate what I do It makes me happy.
my TURBO! Altezza!
