Page 1 of 7 1234567 LastLast
Results 1 to 10 of 63
Thread: RE XXX Subs Amp Strapping Howto? 1Ohm?
    Variable Bitrate Philhop's Avatar
    Apr 2006
    Hi Guys, Hopefully some one has done this in the past , I have two Caliber 2000D Amps and 2 x RE XXX Subs 2ohm Dual Voice Coil It says for amp strapping 2ohms minimum impedance for CA2000D Plus when strapped does this meen I cant goto one Ohms on each sub? I currently run with one amp at one Ohm for both subs. But I want more power so Strapping amps seems like a valid Idea the amp specs are
    2 Ohms 750W RMS
    1 Ohms 1250W RMS
    Each sub is rated at 1400 W RMS so you can see why I would want one ohm through each of the subs.
    Any Ideas?
    my TURBO! Altezza!
    ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
    _
    Mar 2004
    Little Elm, Texas
    hu!?
    amp strapping?
    what is that?
    and I'm not understanding your post very well either. Possibly try hitting the enter key to separate your thoughts and maybe using punctuation?
    btw - I hope you've beefed up the rest of your electrical system.
    Jan Bennett
    Elsewhere
    Bridging amps, perhaps?
    How about the Wiki?
    Apr 2006
    Sorry About some of my posts I have a tendancy to rush things -
    Hmmm I have a yellow top Optima, May need a HO Alternator soon
    120A electrical Draw at the moment.
    Amp Strapping - Some amps are capable of being strapped together to provide twice the power. Only like models can be strapped together.
    http://www.eaudio.co.nz/CA2000Dplus_...no_graphic.pdf
    my TURBO! Altezza!
    Jun 2005
    chicago, Illinois
    you may even consider using multiple batteries
    PROGRESS:
    _
    Mar 2004
    Little Elm, Texas
    ok - now I understand what you mean by amp strapping, must be a European term..lol
    many amps out there now can be linked together to provide enough power to arc weld with....lovely stuff really.
    Jan Bennett
    Apr 2006
    55 Amp hour battery last about 20 mins on full system crank, Why would I need another battery.
    Im not getting into that I might even throw a Few Caps in at some stage.
    If from New Zealand lol
    Red I dont realy want to Arc Weld anything.
    I want a Diagram of How to wire my dual Voice coils with two amps linked
    my TURBO! Altezza!
    _
    Mar 2004
    Little Elm, Texas
    from reading the owners manual, it sounds like you can't get 1ohm out of the two amps linked together.
    1 ohm stable as an individual amp, but no less than 2 ohm when linked.
    the amps are 1 ohm stable.
    Your subs can be wired up to be a 1 ohm load.
    why do you need to link the two amps to get enough power when the amps put out 1250 watts at 1 ohm?
    Jan Bennett
    Apr 2006
    It says minimum 2ohms so would 1Ohm be less than that or would the minumim of 2ohms be 4ohms bloody confusing!
    my TURBO! Altezza!
    Jun 2005
    chicago, Illinois
    Extra batteries are just a suggestion. Arguable additional batteries are more efficient than caps. Sometimes cheaper than a whole rack of caps
    PROGRESS:
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. FS: 2 mtx 10 inch subs and 400 watt amp with box
    By xdjxklusivex in forum Classified Archive
    Last Post: 02-25-2005, 04:41 AM
  3. recomend me an AMP. stock speakers, no subs.
    By mattress in forum Car Audio
    Last Post: 02-05-2005, 02:18 AM
  4. F/S: Amp & Subs
    By 89Excess in forum Car Audio
    Last Post: 04-17-2004, 11:50 PM
  5. power? Subs w/ amp
    By Jeffro in forum Power Supplies
    Last Post: 10-31-2001, 12:50 PM
