Well I got the vise from home depot and worked like a charm... well it worked but after lots of force turning the damn thing.. It was only $15 so wasn't a bad investment at all. Thanks again for the help.
i've always just used a mini torch and a lot of solder. never crimped before hand... though it would only make the connection more secure
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I always just used setscrew or compression fittingsA Tweeter up near where I used to work modified some bolt cutters for crimping. Worked incredibly well and you had a ton of leverage so it wasn't a chore.
go with the bench vise they work great
if you want a proper crimp this is what turbo was describing. http://www.theinstallbay.com/i/produ.../IBHDCRIMP.jpg
if you want a good connection without spending the money on a crimper just solder it a cheap torch is only like $10-$15 pliers, vices, and vice grips and channel locks are not the right way to do it however it will work I just wouldn't guarantee the connection.
Aron
Absolutely 100% stock
=p&gcustoms]go with the bench vise they work great![]()
Originally Posted by hornyleprechaun
Jan Bennett
yeah i wasn't going to say anything.. he must of read the first post and that's it!
I think he's done that with most of his posts...lol
Jan Bennett
Just o throw my 2 cents in. Many people have said that they solder there connections. Soldering should not be relied on for a MECHANICAL connection, only for an electrical connections. This can be overcome with appropriate strain relief-ing though. It is better to crimp it, and then dump some solder in to make the mechanical and electrical connections nice and purdy.
Michael
