Bench vise.
I got the 1/0 amp kit from knukonceptz and I cannot crimp the terminals onto the 0 gauge wire... What is the best, least expensive way to do this? I wouldn't mind purchasing a tool from walmart, but I don't know what would work. I've strained my puny biceps trying to get the thing crimped but it won't go!
Bench vise.
I used a heavy pair of pliers (the blunt nose slip-joint type), a hammer, concrete floor, and lots of swearing. I use the pliers to hold it where I want to crimp it, and hammer the jaws against the concrete to close them to crimp.
Gen 1: Pentium 3 1GHz - ATX - 2005
Gen 2: Pentium M 1.6GHz - ITX - 2006
Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
...it never ends
unless you can get hold of a hydraulic crimper then solder them on
Yeah I read somewhere about a vise so I'll look at walmart about those. I think I'll hammer against the ground as the last resort![]()
Originally Posted by psyrex
Those are channel locks, and that method will work, won't be pretty, but it'll work![]()
Yeah I looked on home depot's web site and they have this:
http://www.homedepot.com/prel80/HDUS...gim.0&MID=9876
I think that should work for what I want it to do. Thanks again for the help!
Well, usually covered by a pretty red or black sleeve, so you're fine. I solder all connections and then cover them in silicone, so I hope it'll last me a while.Originally Posted by binary.h4x
It's easier and cheaper than buying specialized tools for a single use:
1) Apply hammer.
2) Repeat as necessary.
...it never ends
soldering is probably best, but even then it should be crimped first...
most install suppliers will sell a crimper... it's a block with a slide that you just put the connection in, then slam it with a hammer... there not too expensive, maybe $20-25 & probably worth having if your working with this stuff
crimp it one way - as in pushing the two tabs inwards towards the wires. then turn it 90 degrees and fold it all together if you will. then apply solder. You should be golden.
oh yeah - then heat shrink or cover with the rubber covers. Just don't leave it all exposed.
Jan Bennett
