Results 1 to 10 of 15
Thread: stupid speaker question.
    Jul 2006
    My 96 Civic has 15w nominal, 30w peak speakers in it. I have a pair of Kenwoods that fit nicely, but they're 50w nominal, 250w max. I'm pushing it out of the stock head unit because it sounds fine. What problems will I run into if I swap the speakers? Should I sell them and invest in lower power speakers?
    Oct 2004
    NY
    they will probably work ok, & it'll probably sound better than the stock ones, but the speakers won't see there real potential until run with a bit more power...
    anything even remotely decent will probably start in the 35-50wrms range... I doubt you'll find anything that is optimised for less that can be considered an upgrade..
    they'll be ok...
    Jul 2006
    Does anyone know where I could find information about the stock HU?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Google?
    Tidder
    Try RevFE
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    if you are looking for new speakers then you should look for something that is very efficient. i think infinity is well known for that. (or a horn driver ;-) )
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    what kind of information are you looking for on the stock HU?
    Jan Bennett
    Jul 2001
    Replace the stocker with a $150 model if you're not lookin to spend much and you'll get a LOT more out of your aftermarket speakers. Panasonic, Alpine, Pioneer, Clarion are all good brands. For $150 you can even get a good mid-line MP3 deck.
    If you've got a keyless entry system you've gotta either relocate the factory radio behind the cupholders in the front and use a T-harness or lose factory keyless.
    Aug 2005
    Pennsylvania
    Quote Originally Posted by Shadow
    Huh?......Since when did you have to do this? Is this for certain cars? I have never encountered this.
    Jul 2006
    Quote Originally Posted by volum3rider
    No, that generation Civic is notorious for locating the door lock sensor in the stereo. Mine, fortunately and unfortunately doesn't have keyless entry.
    The information I was looking for was regarding the amount of power the stock unit puts out. I'd also like to know if there is a preamp out in the back (though I really doubt it). What keeps me from going and finding out myself is the long procedure for getting into the back of the console; they didn't make it easy with this particular model.
    Dec 2004
    Los Angeles Ca
    check with pac-audio and see if they sell an interface for that car and year. if they do, then you know you can stop your searching and you also have a solution. usually pac has some sort of adapter to get pre-outs on stock radio's if it's possible
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Stupid Display Cable Question
    By Chronyx in forum LCD/Display
    Last Post: 07-15-2004, 08:18 PM
  2. Stupid Nano-ITX question...
    By Animepix in forum General Hardware Discussion
    Last Post: 07-06-2004, 05:59 PM
  3. Stupid question about amps
    By Bob0_o in forum Car Audio
    Last Post: 06-16-2004, 08:21 PM
  4. stupid question... What's Cobra?
    By Euclid in forum Software & Software Development
    Last Post: 11-24-2002, 09:29 PM
  5. Stupid question...?again...
    By Meoff in forum General Hardware Discussion
    Last Post: 06-22-2000, 08:09 PM
