Use a fusion generator.
Hi everyone... I have a US 2000 amp pushing 4 IDQ15s. I have a Optima red top under the hood, a yellow top in the back ... Someone told me I might need some caps. Please tell me if I need some caps in addition to the yellow top...
And I was told I need a new aftermaket Alternator. US 2000 amp is 2000 X1 Watts RMS@ 2 ohms Bridged. Can I use a 200 Amps alternator, or do I need a 250 amps one? Please help me out... Thank you
1.9in x 2.9in -- 47mm x 73mm
Originally Posted by supersupra123
what else are you running? i would suspect you had components and an amp for them that could keep up with 4 15's
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I have a three way Eclipse components on the front door and infinity Kappa 2 way on the back door, and a Eclipse amp 400 watts RMS...
So how alternator shold be 200 Amps or 250 Amps???? Is 200 Amps enough to power it up?
please post all the fuse ratings on all your amps as well. and, no... you dont need caps
M10k
My Car Pc Install
My Boat Pc worklog
On USA 2000 Amp, 300 Amps and on Eclipse amp, ist is 80 Amps
