Results 1 to 5 of 5
Thread: should i get an amp?
    Jul 2006
    In my 96 firebird i have in the front pioneer TS-C160R and in the rear two eu-700 6.5" subs. They are currently being powered off of the factory head unit and sound alright execpt when i turn up the bass on my equalizer or try to play my music loud the subs start to kind of distort and dont sound good. Would an amp solve the problem with the subs? Should i get an amp to power just the subs or both the subs and components, if so what are some good affordable amps that would work in my situation?
    specs for the speakers
    http://www.edesignaudio.com/product....=Specs&cur=USD
    http://www.cardomain.com/item/PIOTSC160R
    im a bit new to the whole car speaker/wiring stuff...
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by rmc225
    definately need an amp for the two eu's. they will shine at 100-150 wrms each. are the eu's dual 2 or dual 4 ohm voice coils?
    also you do need an amp for the speakers.
    what's your budget?
    i'd get this amp for the subs.. probably
    http://edesignaudio.com/product.php?...pid=24&cur=USD
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2006
    right now i have them wired for the dual 2 ohm(just connected to two of the terminals on one side)
    so the amp will fix that distorted sound i hear when i turn up the bass?
    i know amps get kinda pricey if i was going to wire the components/subs, so i might just have to get an amp for the subs
    ive never installed in amp before, but ive read there are some that i can wire through my factory wiring. but if i chose to wire it myself how hard would that be for a noob?
    Falls Church, VA
    You are going to blow up your factory radio with those subs connected. Your factory radio should only have 4 ohm speakers connected. 2 ohm speakers are way too difficult for it to drive.
    Now you are also underpowering the speakers which will easily distort and destroy the speakers.
    Your solution is either get a decent amplifier (this does not include amps purchased at Walmart, K mart or Target) or remove the subs. Your choice.
    In regards to your noob question, and please, i am not trying to offend, it seems you are about a 2 on a 10 scale of Car Audio knowledge. Thats fine, everyone starts somewhere. Do what you can to read up on the subject (MANY hours of reading), spend some time asking questions in a true car audio forum (this one is designed for CarPC projects). Try to get to a 5 out of 10 and then start installing yourself.
    If you don't have the time or ability to get to a 5, please stop by your local car audio shop and have them do it. Its what they are there for.
    Good luck
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Will Albers
    Good luck
    how does he know he's a 5? amp installation is pretty simple. what i would suggest is...yes do a lot more reading like will suggested, but also go to a local car computer meet near you and maybe have someone who knows what they are doing help you. if you are in socal you can hit me up and i'll work along side you and help you with questions along the way.
    's
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  3. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
  4. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
