Results 1 to 10 of 13
Thread: A little guidance needed in matching up system
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    So far I've read until my head is about to explode and I haven't even touched the tip of the iceberg when it comes to car audio. I hesitate to ask advice from a audio shop because I can tell they either don't know what they're talking about, and/or want to sell me the most exspensive stuff. I'm not trying to build a show winning system just something that sounds nice and clean.
    My car uses 6.5" speakers in the front and 6x9" in the rear. So far I have a pair of Infinity Kappa 60.7cs components for the front that are rated at 2ohm, 90w RMS. I also have a older RF Punch 400a4 amp, rated at 4x50w at 4ohm or 4x100w at 2ohm. The rest of the system in still in the air at this point. I'm unsure if I should just use the comps up front and not use rears, just go for a sub(s) (with 2nd amp of course). I'm getting conflicting info on whether that is a good solution or not. It would work out perfect for me mounting the subs, as I could put two 10's under the rear dash where the stock 6x9's were, there is plenty of room, and that would save me a ton of trunk space too.
    So any suggestions? I have zero experiance with car audio, just what I've read. I like many people here am a computer geek first, audio afictionado second.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    Jul 2001
    I'd ditch the 6x9s, but I wouldn't mount the subs under the rear deck. You'd need freeair subs and they're not that great performance wise. Also, by bolting a sub to the rear deck you're looking at a great way to find rattles that you'd probably never run into otherwise.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by damarble
    I'm unsure if I should just use the comps up front and not use rears, just go for a sub(s) (with 2nd amp of course). .
    thats what i'd suggest. that's what i did and it sound pretty great imho. save the money on the rear speakers get a better set of comps for the front (4 ohm version) and a nice sub or two in the rear. Image dynamics and elemental designs make some great inexpensive subs that play well with relatively little power.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    ditto what scott has said.
    whatever product you go with, I recomend staying with well known name brands. None of this Rage, boss, jensen, etc stuff you find at wal-mart or the flea market. ID makes great subs that work well on little power and in little air space.
    I have no first hand experience with eD but people seem to love em.
    Jan Bennett
    Jan 2006
    Spokane
    Thanks for the input!
    Quote Originally Posted by scott_fx
    Dammit I should have asked before I bought these comps. (Just 3 days ago ) Why should I be looking for the 4ohm versions? And I really don't want to spend more than I did anyway. I was originally going to go with the Infinity Reference series instead as I thought they sounded damn good for the price, much better than my stockers, but the Kappa's weren't that much more.
    MY INSTALLATION LOG
    Dec 2004
    Los Angeles Ca
    easy answer....you'll get better sound from an amp pushing 4 ohms rather then 2. about half the power from your amp though..but you'll notice an improvement in sq.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2005
    ::kicks jensen head unit under bed::
    1999 Lexus GS300- (going VIP)
    1993 Lexus SC300-Turbo (Totaled by idiot driver)
    1996 Lexus SC400- (Totaled by brother)
    1972 Datsun 240Z- (WIP)
    1994 Toyota Camry- (sold)
    _
    Mar 2004
    Little Elm, Texas
    that's a damn fine place for that jensen...possibly even in the trash compacter
    Jan Bennett
    Nov 2005
    Quote Originally Posted by Red GTi VR6
    I guess I better throw the jensen 6 x 9's with it as well.
    Jan 2006
    Spokane
    How much of an improvement? Obviously not "double", but if you could put it into numbers or percentage (I know, hard to do) how much better?
    So what's the point of making a 2ohm speaker? Just a cheap way to raise the wattage rating?
    MY INSTALLATION LOG
  1. Ground noise in system
    By TyBong in forum General MP3Car Discussion
    Last Post: 09-20-2005, 03:13 PM
  2. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 03:15 PM
  3. Security System thoughts
    By techy101 in forum General MP3Car Discussion
    Last Post: 07-28-2005, 04:42 AM
  4. Couple of questions about the monsoon system
    By Bugbyte in forum Car Audio
    Last Post: 07-07-2005, 08:47 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
