Results 1 to 10 of 11
Thread: Sub problems still
    May 2006
    Sub problems still
    Hi i had a post a while back about sub rattling. Now i got my new sub an Elemental design 13kv.2 and i still have the same problem. So my old sub was not blown, but im still stuck with this problem. Its not really a rattle. The sound coming from the sub is like when the bass hits, its not clean. Its like staggered. Im thinking its my amp now cause i replaced everything else. Could the crossover on my amp be messed up, its a rockford 2002 model. Had it for about 2 years now.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by flyguy7150
    did you use the same box? did you build that box?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    May 2006
    yes same box i built, but its sealed and there arent any leaks
    May 2006
    ok i started pushing against the sub and now i hear a squishy air sound coming from the sub. Probably around the rim of the sub. I used all 8 screws for the sub, and the rim itself is like a big gasket. Help please
    Jul 2001
    RTV silicone to the rescue! You can either use RTV (DO NOT GET IT ON THE SURROUND) or you can get some thin weatherstripping from HD or Lowe's and stick it on the back of the basket.
    May 2006
    can i use the same silicone i used on the seals of the box?? I used silicone II (black). And just let it dry first? But how will i put it on when i carpet it?
    Pok
    Pok is offline
    Jul 2006
    Coffs Harbour, Australia
    If you are using very thick carpet, you could be experiencing a leak through the carpet itself.
    Can you hear the air come out from all around the sub, or one particular spot?
    May 2006
    Ok guys i figured out what is wrong, im using a rockford 2002 amp, 2 channels, i tried the sub with one channel, then the other, one of my channels is making it sound like crap. One is working good and sounds clean, the other is making the distorted bass. Is it time for a new amp?? or can this be fixed?
    Dec 2004
    Los Angeles Ca
    there is a guy on the pheonix gold forums that fixes amps. you could sing up there and see how much he'd charge to fix it. it may be worth while to just get a new amp though. Elemental Designs has some good amps that are relatively inexpensive.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2006
    Quote Originally Posted by scott_fx
    yea im looking at the nine.2. Im hoping i can fix this first, cuz i just bought a bunch of other stuff, like hids.
  1. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 06:17 PM
  2. Car voltage problems
    By cheerio in forum General MP3Car Discussion
    Last Post: 08-16-2004, 09:01 AM
  3. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  4. Setup nearing completion, having all kinds of problems (yeah i did a :search:)
    By therussman2002 in forum General Hardware Discussion
    Last Post: 06-21-2004, 07:09 PM
  5. Shutdown Problems - Troubleshooting Guide
    By brettwmd in forum Power Supplies
    Last Post: 05-28-2004, 12:46 PM
