Results 1 to 10 of 11
Thread: carputer and amp wiring
    Apr 2006
    Cleveland... soon Austin
    I'm going to put an amp and my carputer in the back of my xterra. What gauge power wire is recommended if I want to run only one wire back and split it to the two electronics? Or is that a bad idea?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by ohioG35
    to answer that, we really need to know how many amps are going to be flowing through the wire. what are the fuse ratings on the amp and the psu?
    you can run one wire and split it with a fused distro block w/o a broblem. I have one wire running 3 amps, an active x-over, and the computer
    check out www.knewkonceptz.com for good wire at a great price.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Apr 2006
    its just a 50x4 alpine amp and a carputer that doesnt pull too much juice. I like the idea of the distro block. the link you added is down.
    Dec 2004
    Los Angeles Ca
    are you planning on adding a sub and amp later on down the road?
    http://www.knukonceptz.com/
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Apr 2006
    yeah, maybe a 10" sub with a 100w rms. something in that range.
    _
    Mar 2004
    Little Elm, Texas
    Those two links should help.
    Jan Bennett
    Apr 2006
    perfect, thanks alot
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Red GTi VR6
    it's been so long since i've read the sticky threads but is this info on them? If not..mods...can you make this thread a sticky?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    hehe - I'll jsut start a new thread with this information in it, we'll see if it gets stickied
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. Questions re: my Carputer amp, EVIC, etc.
    By vettejock99 in forum Car Audio
    Last Post: 09-07-2005, 04:39 PM
  3. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  4. Powering Carputer and amp ...
    By TxMazda3 in forum Newbie
    Last Post: 06-03-2005, 04:12 AM
  5. Using existing amp wiring for OPUS/Inverter?
    By SwapMeet in forum Power Supplies
    Last Post: 11-12-2004, 04:39 PM
