i've heard of some using PC heatsinks with fans across the amp with that grease at the bottom. no clue if it works. i'd assume it would... they also make fans that fit right over amps, you could try that.
ok i got a feeling this is gonna be a hot summer. i can only run my subs for like 5 or 10 minutes before that smell starts. my subs are in my trunk and i need some ideas about how to keep them cool. it would be much appreciated![]()
1999 Lexus GS300- (going VIP)
1993 Lexus SC300-Turbo (Totaled by idiot driver)
1996 Lexus SC400- (Totaled by brother)
1972 Datsun 240Z- (WIP)
1994 Toyota Camry- (sold)
heatsinks hummmmm......... how would i hook those up?
usually with thermalpaste and a screw. a fan or 2 should do the trick though. your amp is designed to dissapate heat think of the case as a big heat sink. anyhow. if its overheating, then use a fan to blow the hot air away from the case. good luck.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
