Results 21 to 30 of 34
Thread: S10 sound system
  1. #21
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    I'm personally a fan of the Orion amps, and the Alpine amps .. every ones got thier own pref's but those are mine, never had a problem w/ them, they run well, and really bump,
    unless you plan on hooking the subs up to your rear channel so that you can fade left/right then a mono amp will do you just fine .. wire them in parallelor series depending on the impedance of your subs to match your amp, 2-ohm stable is fairly common
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
  2. #22
    Jul 2006
    Quote Originally Posted by Shadow
    Read?
    Didn't mean 2 channel as in that, wrong use of terminology on my part.
    I meant, how do I know that amp puts out to 2 subs? Will it just say in the specs or what?
  3. #23
    Feb 2006
    YOu go to www.google.com and type in "subwoofer wiring" and read some of the links.
    Forgot, you have to either A: hit the enter button on your keyboard. or B: click on the "Google Search" button. After the typing.
  4. #24
    Jul 2006
    Boston, Ma
    any number of subs can be wired to one amp, its just a mater of matching power[rms watts] and impedance[ohms] for the most part, if you wire two 4ohm subs in parallel you end up w/ a 2ohm load on the amp ..
    http://caraudio.biggz.com/parallelseries.html
    so 2 subs that each run at X watts@Yohms would need an amp that runs at 2Xwatts@Yohms ...
    --worklog--
  5. #25
    Jul 2006
    So, to run a pair of 400w RMS each subs @ 4ohm/each, I will need a 2ohm stable amp that can supply 800RMS, correct?
    Thanks for the help red.
  6. #26
    Jul 2006
    An amp that does this:
    500 Watts x 1 RMS into 2-Ohms
    Would do the job for a pair of Reference's wired in Parallel then, wouldn't it?
    (The 10" Reference's I have looked at are 250RMS @ 4ohm)
  7. #27
    Jul 2006
    Boston, Ma
    correct ... two 250watt@4ohms sub wired together in parallel would need a 500watt@2ohm stable amp
    --worklog--
  8. #28
    Jul 2006
    Alright then, thanks for the help. Looks like I know what I will be getting come pay day.
  9. #29
    Jul 2006
    Los Angeles
    Hey fatmanmitch,
    I'm a noob here but am well-established on a few of the other Car Audio boards.
    You will not get very much "kick" out of 4"x10" speakers! They could be used for what is commonly referred to as "rear fill" or to create a bit of ambiance. Generally, Hi-end car audio installs concentrate on getting all the sound "up front" and at ear- or eye-level, just as if you were looking/listening to a concert from the first several rows. You would have all the instruments and vocals coming from in front of you from Left to Right across the stage.
    To reproduce all the frequencies evenly, from low to high, you need some type of subwoofer system. If done properly, even with the subwoofers behind you, you can get it to sound as if the bass frequencies are coming from the front of the vehicle. In my system, the bass guitar and kick drum is centered under the rear-view mirror but out over the hood of my car and usually behind the vocalist (on good recordings, of course.) To achieve "UFB," or Up Front Bass, you generally do not want the subwoofers playing any frequencies above 70hz-80hz, and sometimes nothing higher than 50hz. Your front speakers should play down to this frequency and then cut off below that.
    For the money, that Infinity Reference sub is a great performer! And as stated above, if each sub has a Single 4-ohm voice coil, and you wire TWO of those Subs in Parallel, you will end up with a 2-ohm load for the amp.
    So Yes, for that setup you want a MONO (Single Channel) Amp that is Stable into 2-Ohms with Approximately 350-500watts of Real Power (Look for the CEA 2006 Rating Specs.) Those subs don't need a ton of power to sound good. It's always good to have extra power, but why pay extra for power you don't need?
    If you think you will want to upgrade in the future and add an amp to power your front speakers, it is very cost effective to buy a Multi-Channel amp Instead of a MONO amp. A lot of times you can find a good 4-channel amp for the same price as a Single Mono Subwoofer Amp.
    With a 4-channel Amp, you would use 2 of the Channels to power your front speakers (Left & Right). Almost all multi-channel amps allow you to "bridge" or Combine 2 Channels into One, more Powerful Channel (usually close to Double the power of a single channel.) So with the remaining 2 Channels (lets call them Channels 3 & 4) you can bridge or combine them to create a single "MONO" channel to power your Sub or Subs, depending on how you wire them. So your 4-channel amp essentially becomes a 3-channel amp...2 channels for your front Left & Right Speakers, and One Channel for your Sub(s).
    Or you could bridge Channels 1+2 for One Sub, and also Bridge Channels 3+4 for the Other Sub. As you can see, a 4-Channel Amp is very versitile, and will work with a multitude of setups if you decide to upgrade or change your system in the future. This can usually be done for at, or near the same cost as a Mono Amp!
    For an Excellent Tutorial on Amplifier Configurations and Subwoofer Wiring Configurations, check out the Tutorials on the JL Audio web site:
    http://mobile.jlaudio.com/support_pages.php?page_id=127
    I have a few more recommedations regarding the subwoofers, if these will fit:
    Phoenix Gold Radial RSd 10 or RSd 10d (Dual Voice Coil Model or DVC) Subwoofers. Excellent Sound Quality & Output in a small sealed enclosure.
    Links: http://www.phoenixgold.com/2004/rsdspeakers.html
    http://www.crutchfield.com/S-6WIEWcP...sp?i=218RSD10D
    They are a bit more expensive than the Infinity's, but nearly the same mounting depth, but they will work great in a slightly smaller enclosure than the Infinity's (.3 to .5 cu.ft. sealed, as opposed to .75 cu.ft. sealed for the Infinity's.) You can find them cheaper on eBay or pricegrabber.com, etc.
    Or the DAYTON RSS265HF-4 10" HIGH FIDELITY SUBWOOFER
    These are also Excellent and only 5" Mounting Depth! However, they do not come in a DVC version, only single 4-Ohm voice coils. Again, more expensive, but they have excellent Sound Quality (SQ) and output!
    http://www.partsexpress.com/pe/showd...number=295-460
    None of these subwoofers will give you massive output, but I don't think you're a bass head and going for that anyway. They all have above average output while still achieving great Sound Quality.
    Hope this isn't too much for you to absorb at once...guess I went a little crazy on my first post here! Good luck!
  10. #30
    Jul 2006
    Boston, Ma
    well said bbfoto, catch all that fatmanmitch? haha
    --worklog--
  1. Excellent Sound System Setup Website
    By probability in forum Car Audio
    Last Post: 06-21-2006, 02:37 PM
  2. 4-way active audiophile sound system
    By chuyler1 in forum Car Audio
    Last Post: 02-27-2006, 11:37 AM
  3. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  4. Mpxplay doesnt work with Sis530 sound system onboard
    By zamboni in forum Software & Software Development
    Last Post: 06-23-2000, 01:11 AM
  5. How do you get sound in to your system???
    By DaPyro in forum General Hardware Discussion
    Last Post: 02-28-2000, 01:10 AM
