Results 1 to 9 of 9
Thread: Can't figure out why amps run so hot HELP
    Jul 2006
    New York
    Angry Can't figure out why amps run so hot HELP
    I'm having a problem thats driving me crazy, hopefully someone out there can shed some light...
    I'm running 2 Diamond Audio 10 inch subs to a Diamond D6 1500 watt class D amp at 2 ohms (so they are only getting 750 watts total). There is a 1 farad capacitor on this amp. I also have a 400 watt Eclipse 4 channel running to eclipse interior speakers. My head unit is an Alpine 9835. All power cables are 4 gauge, including two 4 gauge ground wires coming off of the battery (to compensate for two 4 gauge power wires going to the amps). Both of these amps get hot enough to cook an egg off of. The sub amp even goes into thermal protection, but will come back on after a minute or so of the music being turned down. I can't figure out what is causing this. All the amps are matched to the power requirements of the speakers, and the Diamond amp which is supposed to be insanely stable is only running at half power.
    I've been deciding on whether replacing the battery, getting a second battery, or getting a more powerful alternator would help anything, but everyone I talk to tells me something else so the average response is none of those will work.
    Any help or insight at all would be greatly appreciated...
    Jul 2001
    Probably overimpedance. Could be your gains too.
    Oct 2004
    NY
    yeah, the class d shouldn't run real hot..., is it mounted upside down? that could also cause problems with overheating... along with too low of an impedance total..
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    its because you posted twice
    Jul 2006
    New York
    Red face
    wow, quick response. And the posting twice was accidental, fisrt time using one of these. The gains were set professionally, so I figured I could trust that. I'm not too familiar with the concept of over impedence, is there another way to lower that other than gain? There is no bass boost knob on the sub amp btw.
    And as far as mounting, the amps are mounted to boards on each side of the trunk, so not flat, but not quite vertical either, kind of like \ and / if you can picture it...
    _
    Mar 2004
    Little Elm, Texas
    FAQ: Determining proper gauge wire/fuse size/battery size/alternator size - make sure you're running the proper gauge wire first.
    FAQ: Proper Wire Termination and Connection Methods - make sure your install is done correctly
    http://www.350z-tech.com/zwiki/Tutor...plifier_Tuning - make sure your amps are tuned correctly.
    Once you've done all of this, then come back and ask your questions. If you still have them.
    Jan Bennett
    Jul 2006
    New York
    Thanks Red GTi, this all looks very helpful (except the last link goes to a blank page...)
    As far as amperes and wire gauge, I'm not sure how to convert amplifier watt output to amperes drawn. I have two four gauge wires running from the battery, one to each amp (1500 watt class D sub and 400 watt 4 channel) with two four gauge wires going to ground from the battery (ground wires from the amp are also 4 gauge). How wold I convert that into amperes?
    Also, I just bout an Interstate Red Top battery which I will put in with the same setup tomorrow (replacing honda stock battery). The only other thing I can think of is to change power wires from alternator to be 4 gauge as well...
    As for the install, wires are all clean, all power on one side of the car and all RCA on the other. I hope there's a difference tomorrow...
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by vortex1521
    look at the fuses on the amps. add them up and that is how many amperes you can draw at max.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    they all worked for me...
    which one didn't work for you?
    Jan Bennett
  1. mach 460 amps
    By meth84 in forum General Hardware Discussion
    Last Post: 06-27-2007, 08:28 PM
  2. Tank battery & ventilation; run lines carrying high voltage
    By PredatorCoder in forum Power Supplies
    Last Post: 02-13-2006, 03:09 PM
  3. BIOS shut pc down when it gets too hot?
    By muldrick in forum General Hardware Discussion
    Last Post: 12-16-2004, 09:26 PM
  4. Those who run fans for cooling??
    By osirisdon in forum General Hardware Discussion
    Last Post: 06-12-2003, 09:30 AM
