sounds like the amp is going into protect mode. how are the two subs wired?
i have 2 alpine e type 12"s with a alpine vpower 650 wat amp and im running a fosgate cap but not shure what kind now when ever i turn my volume past 16 the subs turn off and i have checked the amp the subs and the cap and they are all good the amp gets hot but i had it checked out and they said its all good now if i only hook up 1 sub it works fine but if both r hooked up it shuts off i have no idea what to do i think it kight be the deck or a short in the car someone please help me.![]()
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I did an install of that amp on two 12" type R's (2ohm DVC) and it works really well, i agree w/ scott_fx, check to make sure your subs are wired properly, so you have the right load on the amp
since i think the e type only comes in a 4ohm single voice coil, i would suggest making sure that the subs are wired in parrallel so that there is a 2ohm load on the amp, therefore the amp would be pushing 600 watts [more then the RMS for those subs but not unreasonable, they should be able to handle the extra 50 watts]
hope this helps ...
MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2--worklog--
i have both 12's hooked into the mono amp but i have a 4 gage power wire runing into a spliter one power wire goes 2 my 450 wat 6 channel and one goes 2 my cap then 2 m,y vpower amp but i already had the amp checked out and it works fine but i just tried hooking up another deck and it worked fine so i think it might be the deck but still need advice on what 2 do???
Originally Posted by moonjavie07
please explain how they are hooked up? let us know where each speaker lead is getting attatched to.
M10k
My Car Pc Install
My Boat Pc worklog
well if it is the deck [i assume you mean headunit/radio] then i guess your options are replace it, get it repaired, or umm replace it, what deck is it? how old and where did you buy it .. or is it stock?
u might want 2 try typing complete words and use punctuation bcoz i hav no idea wut u r tryin 2 say and also lay off the speed.Originally Posted by moonjavie07
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
i have red hooked 2 red and black hooked 2 black but i sent my deck in earlier 2day and i tried hooking a new deck up again 2day but it still does it ???
Is it really hard to type using correct punctuation, spelling and capitalization? "2" is one keystroke, "to" is only two; where's the shortcut?
Here's so moonjavie can read:
is it really hard 2 type using correct punctuation spelling and capitalization OMG LOL!!!1!!! u have 2 b kidding me
so you have two subs? are the dual voice coil? do you have each terminal on the voice coil wired to it's corresponding terminal on the amp? (i.e. all the +[red] terminals on the speakers each going to the +[red] on the amp and vise versa with the -[black terminals])
M10k
My Car Pc Install
My Boat Pc worklog
