Results 1 to 6 of 6
Thread: Alpine PXA-H701 Volume Control
    Newbie kingmissel's Avatar
    Mar 2004
    NY
    Hi. I was wondering about the main volume control when using the alpine H701. I have a computer with a soundblaster PCI card, using the Optical output to go to the H701 (i am just about ready to buy the H701). I won't be using a HU and I don't want the alpine controller. Will the volume on the PC work correctly throught the Optical output? I don't quite understand how the volume would change on a digital signal.
    So, my main question is can I use the H701 with no controller, and rely on the volume in the PC even when using optical output.
    Thanks!
    -- kingmissel
    IN: P4 2.4Ghz Mini-Itx, 512MB Ram, Slot-load DVD/CD-RW, Opus 150w, 2nd Battery, JL Audio 500/5 amp, TouchScreen, GPS, Cell Internet Access, 802.11G
    Not IN:[I] FM Tuner, OBD-II
    Preview: temporarily down
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    no, you need the controller.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Oct 2004
    NY
    you have to have either the controller, or a compatable head unit for control.. by itself the brain will do nothing...
    _
    Mar 2004
    Little Elm, Texas
    what the others have said...
    I think we need a 701 FAQ....
    scott and turbo, what do y'all think?
    especially since this question gets asked so much.
    Jan Bennett
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Red GTi VR6
    a faq would be cool. NOT IT!
    M10k
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    heh - since I'm not real sure what all FAQ there are about it, other than do I have to use the controller....
    Jan Bennett
  1. Fader, Balance, Sub Volume Control w/o Headunit or EQ?
    By The unL33T in forum Input Devices
    Last Post: 03-24-2009, 03:23 PM
  2. Change behaviour Volume control
    By DbXL in forum Centrafuse
    Last Post: 07-09-2006, 12:09 PM
  3. Roadie Volume Control
    By tjp12100 in forum FrodoPlayer
    Last Post: 06-21-2006, 04:30 PM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 11:43 AM
