something is wrong here...let me think about it. Those sb live cards probably put out around 1volt. every amp now adays can handle at least 4.
are you using kxproject drivers?
I have built my system, But I find that the siginal coming from the soundcard (sblive 5.1) is too strong / high , I have 2 pots on my 4 channel amp, i have to turn them all the way down for the signal to be acceptable. the amp does not have high/low input settings like some other amps, it is just a basic model.
Does anyone know if there is some kind of "in-line" attatchment i can connect to the audio leads before they connect to the amp to reduce the signal. - i was thinking of a resistor, but i think this may degrade the signal quality?
P.s. I have already tried software settings in volume control and sblive setting, but the siginal is still too high for the amp.
I also have 2 ground loop isolators in line. to eliminate the buzz.
Celeron 2ghz, 1 gig ram, 200 gig sata, DRU-R100 radio, wifi g, 7"lilliput touchscreen, opus 150w dc-dc, laptop slot load Dvd, BU-353 GPS , Destinator, Road Runner MC2.0
http://www.mp3car.com/vbulletin/show...ord+focus+2000
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
for starters i would recommend gettin rid of the ground loop isolators, they're just covering up the problem. work through all your grouding points etc, theres an excellent post about it at the top of the forum, i'm no expert but i don't see why using a resistor to drop the output voltage would do any harm to the signals integrity. resistors cost pennies, so its no huge loss if it doesn't work!
p.s. i once had a ford, and it was the worst thing on the planet for finding a good gronding point!
Originally Posted by shuggyboy
have you tried to turn down your master and/or your wav volume?
M10k
My Car Pc Install
My Boat Pc worklog
I have tried adjusting the master and wave etc ... I dont know if its the amp im using, Dont get me wrong, It does work,,, but i have to turn the pots right down to near enough the lowest setting or else the siginal gets distorted and is far too loud,, I mean faaaar too loud..
can you get a siginal reducing in line thingamy? I have looked and cant seem to find one..?
Im re-fitting the system into a new car,,, I had a look through the forums regarding whining noises and grounding issues,,, so when I re-wire it, I will do it with good solid grounds, and also ground the amp and chassis of the pc,,, and see if I can do away with the ground loop isolators.
I will keep you posted.
what is the problem with turning your gains down? it sounds like that is working and as long as everything is set up properly, having your gain all the way down is a good thing. but i dont think that everything is working properly.
i personally would try a different card or hook it up to the onboard sound first. try to isolate the problem.
if you're in socal you can stop by my house. i have a couple soundcards laying around that we can test out... edit: I just realized your steering wheel is on the right...probably not near socal after all
M10k
My Car Pc Install
My Boat Pc worklog
lol, I dont think you would be local, Unless you stay Near Glasgow, Scotland.Originally Posted by scott_fx
Thanks anyway,
I Wired up the system last night, But I have not completely finished yet, I have tried both, the on-board sound and the soundblaster live, both are the same, I am starting to think it may be down to the cheep *** amp I bought from ebay! It looked the biz, as it was so small it fits in behind my dashboard nicely http://cgi.ebay.co.uk/BANDIT-500W-WA...QQcmdZViewItem
I will try a few other things and keep you posted.
Cheers![]()
do you have a home a/v reciever? or even a tv with rca inputs? try hooking up the computer to one of those devices. see if you are having the same problem. this will tell us if the problem is the amp or the computer.Originally Posted by shuggyboy
M10k
My Car Pc Install
My Boat Pc worklog
If you bought a cheaper amp off of ebay (any amp that states its max power instead of rated power!) there is a good chance that it is the root of your problem. I have an SBlive card and i think that the signal is a bit on the weak side when driving my amp, certainly not the other way around!
Like Scott_fx said, try to isolate your problem using trusted equipment. But looking at that ebay page its quite likely to be the amp.
Originally Posted by jazzbob
jazzbob...if you haven't installed the kxproject drivers for that card yet...GO DO IT NOW! it will make a ton of difference on how good that card sounds
M10k
My Car Pc Install
My Boat Pc worklog
