+ Reply to Thread
Results 1 to 10 of 11
Thread: amp input wiring question
    Jul 2006
    hello. i am wiring a kicker kx650.4 amp with two image dynamics IDQ10D4 V.2 subs.
    i have a question...im going to tap into the rear door speaker's wires, so do i need a line level converter? i talked to radioshack and they said i could just crimp on rca plugs onto the speaker wire. is this true?
    thanks
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    yeah you sohuld now have a problem, take a Rear Right, a and Rear Left, split, , one eng goes to the speker, second ends are going to the amp
    Yev
    R. T. F. M
    Jul 2006
    Quote Originally Posted by Yevmeister
    Yev
    thanks...so using rca plugs on speaker wire is no problem, right? so whya do they sell that line level converter for 20 bucks? hwat does that little box in it do?
    also, can i just tap into the right speaker wire to get a signal for both subs?
    thanks
    2004 C230K SS
    Custom Silver CF Enclosure with 2 Image Dynamics IDQ10D4 V.2 Subs and Kicker Kx650.4 Amp
    Jul 2006
    Quote Originally Posted by rlee02135
    thanks
    sorry for the bad writing, im using my sisters laptop because my computer crashed and im not used to these tiny buttons.
    2004 C230K SS
    Low Bitrate Epon's Avatar
    Oct 2005
    I wouldn't just snip-snip up the RCA's and splice another wire into them; the wires inside the RCA cables are tiny and gay to work with. I've seen an RCA adaptor that you can then "convert" the RCA male end to your own speaker wire.
    Jul 2006
    Quote Originally Posted by Epon
    im not just nsnipping up a rca cable. im taking these:http://www.radioshack.com/product/in...entPage=search and putting speaker wire into them and plugging it into the amp's input. do you think it will work?
    thanks
    2004 C230K SS
    Jun 2004
    Rochester
    You WILL need a line-level convertor. The signal going to your door speakers is "High-Level" or "Speaker-Level". Your amplifier needs a much "smaller" and lower power signal. It needs a "Low-Level" or "Line-Level" Signal.
    A line-level convertor will take a speaker-level signal and give you a line-level signal that your amplifier can deal with.
    Some amplifiers can take either speaker-level or line-level signals, but RCA jacks almost always carry signals that are line-level.
    Peace.
    Newbie Imy01's Avatar
    Jul 2006
    Okay, here's the deal...
    From reading the thread it is my understanding that you want to know if you can take an active speaker wire, add the phono plug from radio shack to the end of it, and plug it into your amplifier. I'm pretty sure that this WILL NOT work. Why? Because there is power running through that speaker wire, and RCA cable is not made to have significant amounts of power in them.
    Why do they sell line level converters, or AKA line output converts? Because "what that little box does" is it takes the watts out of the signal coming through the speaker wire. If you put pure speaker wire into your RCA inputs like you are proposing, you are going to either A) Fry your amp; or B) Get a distorted sound, or at least not nearly as good a sound as you would if you did it properly.
    If cost is a problem, I would recommend using the Tsunami line output converter, available at Circuit City. Here's the link:
    http://www.circuitcity.com/ssm/Tsuna...oductDetail.do
    What you want to do with this is basically tap your speaker wire that is going into your rear door speakers, or better yet, if you have 6X9's mounted above the rear seats, tap into those. Run your positive from the left speaker to the positive on the line output converter, and run your your negative from the right speaker to the negative on the line output converter (or vice versa if you want). Then, connect RCA's from the line output converter to the RCA inputs on your amp. Be sure that after you verify your connections, you properly tune the gain on the amplifier as well as the line output converter, if they are improperly tuned you will get distortion.
    I utilize a similar setup in my car and it works great for me....
    Good luck.
    Jul 2006
    Sorry walky_talky20, musta been posting same time as you, but we said the same thing anyway...
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by walky_talky20
    Peace.
    thank you...i was amazed at the bad advice that was given before this post.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
+ Reply to Thread
  1. bi-amp wiring question
    By scott_fx in forum Car Audio
    Last Post: 05-13-2006, 01:33 PM
  2. Carnetix 1260 Wiring Question
    By dante19 in forum Power Supplies
    Last Post: 03-02-2006, 11:45 PM
  3. HELP, Input Signal to AMP
    By Power_nisse in forum Car Audio
    Last Post: 06-22-2005, 12:35 PM
  4. Quick AMP / Fuse Size Question
    By tbird2340 in forum Car Audio
    Last Post: 06-07-2005, 12:53 AM
  5. Wiring harness question
    By aegray in forum Car Audio
    Last Post: 01-10-2005, 04:28 PM
