Originally Posted by Toehead
first thing to do to trouble shoot it is disconnect the mixer. wire the h/u straight to the amp and then wire the pc straight to the amp.. do you still have the noise?
Let me start off and say that I did search, and my problem is odd in that it is the reverse of any that I could find when searching.
I got rid of all of my speaker noise for the most part. HOWEVER, I get alternator whine when listening to the headunit with the carputer off. If I turn the carputer on, silence. Not a hint of noise, and my amp is turned up.
Specs are as follows:
dell laptop, powered through invertor and ac power supply
sony x-plod craptastic deck.
all monster cable speaker wires/rca's
run to a kenwood 600w amp which powers the speakers.
All audio equipment is run to a common ground (although the deck ground is a bit long... I took it off the chassis and ran it all the way to the back with thick wire, not sure of AWG, to ground in a common spot with everything else in an attempt to get rid of the noise. Didn't make a difference. )
The noise is only with the carputer off. It doesnt matter whether or not the headunit is on, as long as it is plugged in it makes the noise.
The signals are mixed by a simple audio mixer (shielded) which I made on a radioshack board.
I don't think it is my mixer because if the carputer is on, there is absolutely no noise at all.
If I disconnect the RCA's from the deck, the noise also dissapears.
Any ideas?
1985 Camaro Berlinetta, black with t-tops
500 MHZ dell CP Series
MP3 and ALDL data monitoring/wireless internet
kenwood 600 watt amp, powering pioneer 3 way speakers
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
nope. Only with both connected does the noise occur.
then it has something to do with your mixer. i'm not sure how it was built or even how to trouble shoot that... hmmm anyone?
M10k
My Car Pc Install
My Boat Pc worklog
just a stab in the dark but it seems as though the mixer needs two active inputs. do you have an mp3 player? try removing the laptop and plugging in the mp3 play ro the mixer see if you get the same results that you did with the laptop plugged in
M10k
My Car Pc Install
My Boat Pc worklog
Will try. Thanks for the tips, keep em coming.
Nope, no whine when connected to a battery powered mp3 player directly.
just to get it straight you had the mp3 player and the radio hooked up to the mixer, correct?
M10k
My Car Pc Install
My Boat Pc worklog
no i had the carputer and the mp3 player hooked up....
