Are you using external amplifiers? Stock speakers? Factory amp? Got more than one set of preouts hooked up? You really didn't give much info dude.
I am trying to figure out how to get the audio to the front and rears. I am only hear the rears. below is the image of the processing unit and I have tried every configuration to get audio out both the F and R. If anyone is familar with the Kenwood KVT-911DVD I would much appreciate it.
Project: 1998 BMW 323IC
Installation: Never done
VIA EPIA MII12000/1ghz Ram/7" lilli/M1-ATX/Leadtek BT GPS/Cisco 350 G PC Card/
Not much of a guru when it comes to audio.. I have stock speakers, stock amp, the HD and the processing unit that came with it. What do I need to look for? Then maybe I get myself on the right direction.Originally Posted by Shadow
One way to test out if you are even getting signal out of the headunit is to take a spare speaker and hook it up to the output of the rear signal lines.
I'd suggest bypassing the stock amplifiers. It makes no sense to double amplify the signal, Headunit->Stock amp->speakers. You'd most likely get distortion by doing that. You're factory amp may be busted as far as the rear outputs.
PROGRESS:
Originally Posted by pancit175
Well here is the thing the fronts and rears work fine when I am not using the carpc. If I want to use the carpc it only comes out of the rear and I still can listen to the radio through the front and rear at the same time. This HD has a million settings and I just can't figure it out. someone told me if I get the DSP 5.1 (http://www.bassjunkies.com/text_only...-KDS-P900.html) unit that you can buy as an addon for the excelon then that would solve my problem. I just want to make sure before I go out and spend $$$ on another piece of hardware.
Oh I see...
Well i'm not to familiar with the unit so I wouldnt be able to help much. the only thing I'd check because some higher end kenwoods have a setting for "zone 2" or something like that. So It may definitly my be setting.
If anything I'd suggest talking to kenwoods tech support for an immediate answer
PROGRESS:
Yes, it does have the Zone 2 setting and I played with that and same story. I think making a quick call on Monday to Kenwood as you suggested will hopefully fix my issue or cost me more $$$...![]()
Thanks for you help.
cool keep us posted
PROGRESS:
