Results 1 to 7 of 7
Thread: Amp and sub wiring question
    Jul 2006
    I've got a rockford fosgate P5002 2-channel amp pushing 2 Alpine SWS-1022D dual voice coil subwoofers that are 2ohms per coil. Does anybody know the best way to hook these up so my amp doesn't overheat? The amp pushes 250Wx2 at a 2ohm load per channel and 500Wx1 at a 4ohm load bridged. I was wanting to run both channels but most diagrams show mono configuration. Please help. Thanx Rip
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    With those coils, there's no way to get it 'mono' at 4 Ohms, so the only thing you could really do to get anything out of it is wire down to 2 Ohms (wire the subs so each one shows as 4, then wire down to 2), but then you only get 250w.
    You really need a monoblock amplifier, or if you got the subs recently, return them for the 4 ohm coil version so you can wire the two subs to 4 Ohms.
    Jul 2006
    What would bridging it mono and wiring the subs in a series do?
    May 2005
    Conyers, GA
    If you wire the subs you have in series, that puts out an 8 Ohm load. Wiring the 8 Ohm load to your amp in a bridge will probably put out somewhere around 200~250w (guessing).
    The only ways you can wire those two subs together is either 8 Ohm load, or 2 Ohm load. So you can either do 8 Ohm bridged, or a single channel @ 2 Ohms.
    If you need a way to figure out how to wire it, this is a great resource: http://www.the12volt.com/caraudio/wo...igurations.asp
    Jul 2006
    So to get the most out of my amp I need the 4ohm subs? I have it wired in a 2 ohm load now and the amp gets real hot real quick.
    Jul 2001
    That's because you're overloading the amp. You could either get dual 4 woofers or single 2 woofers.
    May 2005
    Conyers, GA
    Exactly as Shadow said. Your amp is not meant to run bridged in a 2 Ohm load.
  1. Will stock alternator provide adequate ampage? (CPU + Sub)
    By Cadillac_LoungN in forum Power Supplies
    Last Post: 07-07-2003, 02:52 AM
  2. Me=Newbie: Do I need an amp?
    By Strix in forum General Hardware Discussion
    Last Post: 06-28-2002, 09:11 AM
