Results 1 to 10 of 15
Thread: Need help with RCA jacks
    Jul 2006
    I just bought an amp and two subwoofers for my parents truck, it is a 2001 Siverado with a factory cd player, i need to know if they have RCA jacks for the amp and if not what can i do?
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    Pretty much no factory system has RCA connectors. You'll need to get a line out converter and connect it to the rear speaker leads behind the deck. You'll also be able to connect the remote turn on lead for the amp to the accessory wire back there too.
    Jul 2006
    OK, i found this one for about 10 dollars. Im a bit comfused, it says that it is used with head units rated below 12 watts per channel. What does that mean.
    _
    Mar 2004
    Little Elm, Texas
    moved to the car audio forum since it's about car audio.
    btw - Navarro - this forum is dedicated to putting carPCs in our cars. Since your question is geared towards strictly car audio, I'm going to suggest that you find a dedicated car audio forum. it's not that you won't find your answers here, it's that you're more likely to find your answers there and to find them quicker.
    Good luck.
    Jan Bennett
    May 2006
    Calgary, Alberta
    Quote Originally Posted by NAVARRO_X4
    If you look on the front of an aftermarket deck, it'll say something like 52x4 meaning it's 52 watts per channel on 4 channels. So the total deck output power is 208 watts. You need to check your vehicle's manual to find out how many watts per channel is the stock stereo.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    _
    Mar 2004
    Little Elm, Texas
    Maheriano - you're only partially correct.
    Those are the MAX power ratings. Those are also numbers that you will NEVER see out of a head unit.
    If you look at the specs on the HU you will notice that those numbers often correspond with the max numbers in the manual. You should look for the RMS numbers instead.
    Jan Bennett
    Constant Bitrate dvsmex's Avatar
    Mar 2006
    NAVARRO_X4, The line out converters are cheap and will add unwanted sound, Mostly for door speakers. But for subs, it's a hit or miss. What sound system package did your parents get with the truck? Remember, you get what you pay for!
    _
    Mar 2004
    Little Elm, Texas
    The only other option for the guy is to get an entirely new head unit.
    There's a really good chance that that is out of his and/or his parents price range.
    Jan Bennett
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    Quote Originally Posted by Red GTi VR6
    ... and what exactly are you making that assumption on?
    _
    Mar 2004
    Little Elm, Texas
    lets see - he only purcahsed an amp and two subs, nothing else. It's also for his parents truck. he purchased for them...meaning a gift possibly.
    Jan Bennett
  1. minimum distance between power & rca wires
    By michaelrj9 in forum Car Audio
    Last Post: 08-30-2005, 02:02 PM
  2. Replies: 9
    Last Post: 02-14-2005, 12:14 AM
  3. Need small 1/8" headphones to RCA jack!
    By sq_geek in forum Car Audio
    Last Post: 06-26-2004, 08:55 AM
  4. RCA jacks for a SB Live???
    By RaZor in forum General Hardware Discussion
    Last Post: 06-29-2001, 10:02 AM
  5. How to get to my RCA jacks behind the radio?
    By mjohnson in forum General Hardware Discussion
    Last Post: 12-04-1999, 04:27 PM
