Results 1 to 4 of 4
Thread: Want to Add a Sub to Altima
    CgZ
    CgZ is offline
    Jul 2006
    Hi,
    I have a 2003 altima 2.5S. I replaced the two fronts with Pioneer 6.5" TS-G1641R speakers. The sound difference is amazing compared to stock and am hooked on car audio and improving my system.
    Sorry if this question has been asked a billion times. I was wondering what it would take to hook up a sub? What brand would be recommended for the sub, amp, enclosure, any other components needed.
    I want it to be on the cheaper side/middle range. Would it be good starting out with one sub, with having the ability to hook up a second sub. So does that mean a 2 channel amp. Or can a mono amp drive two subs.
    I have read that two 12" subs is just as good as a 15" sub. Is this true. Im a bit confused on amps. Would one 12" sub suffice? Ahh so many questions and I just need to be pointed in the right direction. Any help is greatly appreciated.
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    well, 1. this is the wrong area for this post, would be better in the car audio forum
    2. depends on your price range before i can offer a suggestion
    'cause cheap can a lot of things to different people :T
    _
    Mar 2004
    Little Elm, Texas
    thread moved to the appropriate forum
    also, you might consider hitting up a dedicated car audio forum for such a question.
    It's not that you won't get an answer here, it's that you're more likely to get one on a dedicated forum and more likely to get one quicker.
    Jan Bennett
    Jun 2005
    chicago, Illinois
    i'd suggest going to your local car audio shop to have your questions answered possible even to purchase your equiptment as well. they get paid to answer your questions so they'd be happy to help you
    PROGRESS:
  1. How do I add more commands?
    By boostedGT-S in forum PV FAQs
    Last Post: 11-03-2006, 11:45 PM
  2. add wire to connector and circuit diagram question
    By achca in forum General MP3Car Discussion
    Last Post: 07-29-2006, 11:39 PM
  3. Monitor in 03 Altima
    By jacobdixon in forum LCD/Display
    Last Post: 06-04-2006, 10:39 PM
  4. 2002 Nissan Altima Aux In
    By wheli in forum Car Audio
    Last Post: 04-04-2006, 01:03 PM
  5. Replies: 11
    Last Post: 10-10-2005, 10:05 PM
