PAC makes an adapter.
Hi all,
I have an '01 Pathfinder stock radio (Clarion PN1710N) and have removed the cd changer (CE018) and put my monitor in that slot. I have wired the audio output from my mobo to the input for the changer.
The problem is now the head unit cycles right past the CD input. It goes from AM -> FM1 -> FM2 -> Tape (if tape is in HU) -> AM. There are 3 wires, TXD, RXD and REQ that run to TX, RX and REQ on the head unit, as shown in image below.
So I am guessing the head unit is looking for voltage or signal on these wires to know that it should use the input. Any suggestions on how to fool it into thinking there is still a CD player/changer there?
So close, yet so far...![]()
Shadow,
I have searched but did not find one for my HU. I'll keep looking. If you happen to have a link, it would be appreciated!
[Edit]
I did find this one, but it doesn't specifically list Pathfinder, it lists Altima, Frontier, Maxima and Quest. Will call them Monday to see if it will work.
If you can't find an adapter, you're probably better off reconnecting the changer and hacking the cable to get the audio inputs from the cable. The HU needs to see some sort of data from the changer to enable that input..
Shadow,
I just went ahead and got a new head unit from Crutchfield and got a PAC steering wheel control adapter.![]()
I have one I need to sell![]()
One what? SWC, AUX input module, or head unit?
It's the older model steering wheel controller interface, the SWIX.
The one I got is hardwired, not IR.
You get one of the new Alpines with the plug in the back for that?
