Results 21 to 30 of 33
Thread: Eliminating Ground Loop
  1. #21
    Jul 2001
    Snootch, a square wave isn't clipped, that's just how it looks when you test the audio voltage with an oscilloscope. The regular wave is trying to produce more voltage to complete its sinus rhythm but can't so it flattens out.
    My example of a square wave above is actually a clean, square wave. Did your TV speakers ever blow from playing Super Mario Brothers or Tetris or Duck Hunt? Not unless you had it cranked to some ungodly volume. There's also triangle waves too also referred to as saw waves.
    Just because square wave and saw waves don't look sinus, they still behave as a sinus wave. A clipped signal no longer behaves like a sinus wave.
  2. #22
    Falls Church, VA
    square waves from digital audio sources are very common, but low in amplitude and duration. They are usually less than 6 ms musically before flipping polarity. They also maintain their energy in their designated frequency
    A clipped signal will max out amplitude and extend duration. When the signal clips, it also displaces energy into higher frequencies with just as much amplitude. Your woofer/midbass can handle that 200 watts for extended periods, but after the signal clip, you tweeters are now seeing the energy...
    Clip = distortion = speaker staying at one extreme for two long = dc = bad
    More indepth explanations are available all over the web.
  3. #23
    Jul 2006
    Quote Originally Posted by Shadow View Post
    Nomally I'm not pedantic, but this is driving me nuts! It is *not* a "sinus". A sinus is a cavity in your facial bones. You are talking about sine waves as in the trignometric funcion sine or cosine.
    Secondly, a heavily clipped sine wave is for all intents and purposes equivalent to a square wave. A square wave is the limiting case of a sine wave (ie, the limit as A/L approaches infinity where A is the unclipped sine amlplitude and L is the clipping voltage level).
    Both behave like a superpostion of sine waves (as you've shown in the last diagram), asumming that loudspeakers are linear (which they are not really). Both have very similar Fourier spectra. The sqiggles shown on your sawtooth wave diagrams are waveforms with truncated Fourier series. The fewer harmonics used, the more sinusoidal it looks. It take infinite bandwidth to make a true square or sine wave because the waveforms are not smooth, ie. thier derivatives are discontinuous.
    In any case, they are both probably not good for your speakers. If there is any difference, it's becuase if you have a square wave in a game or bad 80's synth music, it's mixed in with other sounds. If you have a heavily clipped signal, it's nothing but full volume square wave. If you played nothing but square wave (I don't know why anyone would do that), it would have the same effect.
    Anyhow, you've got the right idea to begin with but you might want read up on Fourier theory and linear systems a bit more.
  4. #24
    Jul 2001
    si·nus Audio pronunciation of "sinus" ( P ) Pronunciation Key (sns)
    n.
    1. A depression or cavity formed by a bending or curving.
    Sir, the wave is sinus in nature.
    Will's right:
    So my R-type arcade machine built in 1983 that has an originally equipped and fully functional speaker is an anomaly? What about my friend's MOOG? Is that an anomaly too?
  5. #25
    Jul 2006
    Actually, it's sinusoidal in nature. I suggest that you review etymology of the words in question.
    I never said that you can't play a square wave from a speaker. Only that it is not substantially different from playing a heavily clipped sine wave.
  6. #26
    Jul 2001
    Hmmm, sinusoidal. Etymology aside, sinus is the ROOT for sinusoidal. The rhythm is sinus. The mathematical function to calculate the actual plot is sinusoidal.
    Need a step stool?
    As far as the o-scope is concerned, you're right. As far as the motor in the speaker is concerned, you're dead wrong.
  7. #27
    Jul 2006
    Need a step stool?
    Very cute. At least I know WTF I'm talking about. Nobody but you calls it a "sinus wave". If English is not your first language, I appologize.
    I'm just a dumb electrical engineer. Please explain the difference in terms that an engineer can understand.
  8. #28
    Nov 2005
    CT
    MOOG's are awesome. My friends dad had one. He sold it on ebay for like $600 dollars
  9. #29
    Jul 2001
    The oscilloscope just reads a circuit and displays the freqency and amplitude on the screen. The oscilloscope doesn't care what the wave looks like. A normal 60Hz sine wave looks about the same as a heavily clipped 60Hz sine wave.
    Now, take your 60Hz sine wave and turn it into a square wave which is almost the equivalent of a digital signal. Hook it up to an AC motor and then explain to me why the motor doesn't work the same as it did with the sine or clipped sine wave.
    They appear almost the same on equipment but are completely different to a motor.
  10. #30
    Jul 2006
    Dude, I know what an oscilloscope does, I use one every day. A 60 Hz sine wave does not look "about the same as a heavily clipped 60Hz sine wave" if the scope has sufficient bandwidth to display a reasonable number of harmonics in the clipped sine wave. They look totally different. The clipped sine wave looks clipped!
    The motor *will* work the same with a heavily clipped sine wave and a square wave. That's what I've been saying. Of course, it will be different from a pure sine which is a very different waveform.
    You have yet to explain how they are "completely different" to a motor. You are just saying they are. They look the same on a scope because they are the same, in the limit as the ratio of the unclipped amplitude to the clipping voltage gets very large.
    Do you know the easiest way for generating a square wave from a pure sine wave? You clip it heaviliy using a high bandwidth comparator. This is commonly used for generating digital sync sources from high stability oscillators.
    Look, I'm not trying to beat you up and I'm not on a high horse. You told the original poster about clipping and supplied some nice diagrams, which is good. However your inability to explain the difference (or similarity) between a strongly clipped sine wave and a square wave leads me to believe that you have no real knowledge of EE. In fact I'd be surprised if you've graduated high school. It sounds like you are just repeating stuff that you've heard and do not comprehend any of the theory behind it. That's fine, but you have to know when you don't know something or you'll never learn anything new. Take my earlier advice and look up Fourier transforms and signal decomposition.
    This thread is getting silly and there seems to be nothing that I can do to convince you of some very simple engineering realities. I'm done arguing about it.
  1. Induced noise/Ground loop trouble shooting guide.
    By Will Albers in forum Car Audio FAQ
    Last Post: 01-28-2011, 08:37 AM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 02:36 AM
  3. Re-Ground HU or Ground Loop Isolator?
    By Incinorator in forum Car Audio
    Last Post: 04-20-2006, 07:52 PM
  4. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 08:58 AM
  5. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 03:05 AM
