What kind of car do you have?
The long ground line may or may not cause more problems by picking up more inducted noise.
Now before you all shout at me for asking an FAQ and not searching, just hear me out - I have been reading up on this topic.
I upgraded my RCA cable yesterday from my headunit - amp and it made such a different that I do not have to use a ground loop isolator anymore. I can still hear a slight whine in the music though so it's not 100% perfect.
Just an idea I had if i took the ground line off of the headunit and grounded it to the same point as the amp and pc in the boot, I should be completely eliminating the ground loop shouldn't I as they're all grounded at the same point?
You might want to try running a wire between the radio grounding point and the amp grounding point. That way your grounds stay short but the grounding points are connected. I would use at least 8 gauge wire.
It's a Daewoo Lanos, I just thought by grounding everything to the same place it would eliminate the loop.
Ground lines do not pick up inducted noise or we would have one hell of a problem.Originally Posted by Shadow
Entire car chassis = VERY long/wide ground line
Unless a component finds it easier just to ground through the interconnect. You are correct though, in theory that should take care of a ground loop. Just keep in mind that the longer a wire, the higher its resistance. When a component is grounding, it will take the path of least resistance. Also its not always the interconnect OR ground wire. Sometimes it can be a little of both until it finds an equilibrium.Originally Posted by norbie
Would you do it yourself? (grounding headunit to the same place as amp in the boot)
I'm still getting a little intereference, I'm upgrading the audio cable soon and will try with and without ground loop.
When you talk about high resistance do you mean I would need quite a thick cable as it goes over distance?
Thanks for everyone's help![]()
It's the wiring harness as far as I can see, I haven't followed the cable to see where exactly it's grounded too though.
Did you install your radio? It may need to be grounded to your floorpan or firewall or something.
