Ok, so I'm an idiot and did a search for 9860 and not for dva-9860. When I figured that out I did find this:
“In Europe, the PXA-H701 is identical to pxa-h700. If you have a AINET HU and you connect pxa in AINET mode (not stand alone mode), this is the behavior:
SOURCE: CD ->pxa chose input through ainet cable N°1 or optical input N°1. If pxa feels optical 1 input, automatically switch from AINET analog signal to optical signal.
SOURCE: CHANGER (only if a AINET changer is connected) ->pxa chose input through ainet cable N°2 or optical input N°2. If pxa feels optical 2 input, automatically switch from AINET analog signal to optical signal.
SOURCE: TUNER ->pxa chose input through ainet cable N°1 or optical input N°3. If pxa feels optical 3 input, automatically switch from AINET analog signal to optical signal.
SOURCE: AUX (you need a HU with AUX mode option)->pxa chose analog input through RCA inputs.
Volume, balance, fader, subw level are all controlled by HU. After installation you can disconnect RUX and use only HU+PXA
IN STAND ALONE MODE instead you choose every input manually and Volume, balance, fader, subw level are all controlled by RUX”
Thanks to cougarz for that one!
That being said I have three questions.
First, can anyone verify that this is the way the US model works?
Second, Is there any way to trick the head unit into thinking there is a changer so that optical in 2 can be used?
Finally, when the computer is on but has no sound output does that mean the h701 will switch back to the ai-net interface or does the sound card/computer have to be turned completely off?
Thanks again.
LinkBack URL
About LinkBacks
