Results 1 to 4 of 4
Thread: Thinking of using focal power dual mono amps... how to do 5.1?
    Jul 2005
    CA
    ... or should I not bother with surround sound?
    I'm building speak with me demo car number 2.
    Demo car number 1 is my daily driven g35, pics of that are here:
    http://weblogs.asp.net/ajuneja/default.aspx
    the g35 used the alpine pxa-h701, an alpine dva-9860 headunit, a mcIntosh main amp and a JL sub amp and a shuttle in the trunk, and a xenarc in dash screen.
    This next car will be using a much smaller computer... and I am thinking no extra signal processer, but just hook up the focal amps right to the computer.
    I think this would work... wanted to check with the crowd here if it would...
    Jul 2001
    Got a link to the amps?
    Jul 2005
    CA
    Quote Originally Posted by Shadow View Post
    from red's sticky:
    7. Focal FP Dual Monitor
    This is one bad *** amplifier.
    No prices yet.
    http://www.focal.tm.fr/car/en/index.htm
    Nominal power measured at 13.8V continuously @ 4 ohms: 2x300W RMS
    Nominal power measured at 13.8V continuously @ 2 ohms: 2x400W RMS
    Power in bridged mode measured at 13.8V continuously @ 4 ohms: 1x800W RMS
    Power in bridged mode measured at 13.8V continuously @ 2 ohms: 1x1200W RMS
    Power supplies Dual fully regulated
    Signal/noise ratio >110dB (A)
    Damping factor at 4 ohms >600
    Frequency response (-1dB) 10Hz-45Hz
    Input impedance 13kohms
    Input sensitivity 0.2-5V
    Digital inputs Coaxial/optical
    Output stages Triple Darligton
    Operational amplifiers Burr-Brown
    DSP 2 internal DSP
    180 mips each
    Converters 24-bit/96kHz
    Crystal®
    Software Provided
    Remote control Provided (gain+5 presets)
    Digital graphic EQ (each input channel)
    30 bands of 1/3 octave
    Digital delay line (each input and output channels)
    2 inputs and 2 outputs, 2048 samples max.
    Digital control From external PC via USB port
    High-pass crossover Slopes and frequencies fully adjustable
    Low-pass crossover Slopes and frequencies fully adjustable
    Digital parametric EQ 1 band fully adjustable
    Maximum cross section of loudspeaker cables 10mm = 7 AWG
    Maximum cross section of power cables 51mm = 0AWG
    Protections DC offset
    Short-circuit
    Continuous power
    Thermal overload
    Soft clipping
    Over voltage
    Polarity error
    Dimensions (HxWxD) 50x540x280mm (2x21.25x11“)
    Weight 7.5kg (16.53 lb)
    www.speakwithme.com
    2004 Infiniti G35/Focal 165 K2P front stage /Focal 165CV rear/JL 10W6 sub/Shuttle PC in trunk/Alpine PXA-H701/Alpine DVA-9860.
    _
    Mar 2004
    Little Elm, Texas
    you would be able to set it up like any other 5.1 system if I'm not mistaken.
    The amps are able to be linked and controlled directly VIA the PC.
    However, I personally don't see any purpose for 5.1 in a car. however, some people really want to try for it, more power to them.
    Jan Bennett
  1. Thinking of switching over to M-Atx - how much power?
    By OrangePeel in forum General Hardware Discussion
    Last Post: 05-20-2004, 08:59 AM
  2. Dual Power supplies
    By mbaratta in forum Power Supplies
    Last Post: 05-09-2004, 03:37 AM
  3. Amps - more power vs less power
    By eug in forum Car Audio
    Last Post: 05-04-2004, 12:08 AM
  4. Replies: 13
    Last Post: 11-15-2003, 03:18 PM
  5. Rockford power bd1000 amp, 2 Eclipse amps, FS
    By outragis in forum Classified Archive
    Last Post: 01-19-2003, 07:01 PM
