Page 1 of 6 123456 LastLast
Results 1 to 10 of 53
Thread: Alternator vs Battery
    Jul 2006
    New York
    Which is more important for supplying constant voltage and amperage when the car is running, the battery or the alternator? My voltage drops too low when my system is cranking and it leads from muddy bass to the sub amp going into thermal protect.
    I am deciding between upgrading my stock alternator to 200 amps and a second battery and/or batcap 400 which can charge and discharge like a cap. Any thoughts or advice? I have been talking to a lot of people and get all mixed responses that each swears by.
    Right now I have a stock 04 honda accord alternator, optima redtop battery, and 0 gauge wire running to a distribution block with 2 four gauges going out to a 1500w sub amp and 400w 4-channel. The sub amp pulls up to 110 amps at peak and the 4-channel about 10 amps. They get really hot!
    Thanks for reading.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    if your voltage is getting too low with the engine running, your alternator would be the likely suspect. if it's only an issue during cranking, then the battery would probably be the suspect.
    During cranking, (especially at the very start) the alternator isn't doing anything, so the load is all on the battery until the engine starts up.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Jul 2006
    New York
    It happens when cranking while driving, although the only time I can read the voltage is when the car is stopped since the distribution block is in the trunk.
    I'm thinking a second alternator with a second battery purely for the audio system, but not sure if that much effort/cost is needed. Again, looking for as many different opinions as possible.
    Nov 2005
    CT
    It sounds like you would probably benefit most from a ho-alt.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Huh, "cranking while driving". And " add second alternator and battery)
    First is obvious, how are you cranking while drving.
    Second, you can't have 2 alternators at the same time, but you can have 2 batteries at once.
    Again, if it happens only at crank, you need a new battery, preferably with higher capacity, ckeck out the optima red top batteries.
    If it happens during driving, or both, then your alternator is bad or going bad. A bad alternator can kill your battery as well. I would replace both the battery and alternator. I would consider a better alternator and battery, but it may not need to be better to work in you current setup.
    Michael
    Jul 2001
    You CAN have multiple alternators at the same time.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Show me!!!
    How do you drive 2 alternators off a single engine. While it might be technically possible, with some significant fabbing, there is no way it is easier or cheaper then a high output alternator, especially in the OPs situation.
    Michael
    Constant Bitrate fooshizn1x's Avatar
    May 2005
    714 - Socal baby!
    I count 12.. http://www.teamgates.org/bronco_2004.html
    You might consider upgrading the red-top to a yellow top depending on what one you have and what will fit in the location you have it... or just add the yellow top to the mix, put an isolator on it so it will stay charged, but it will use the red top for the cars regular stuff, and the yellow top for the system.
    With your engine not running, how long can you play your system at a relatively loud (not all the way up.. but like 2/3) volume before you cant start the car?
    Sell me your stuff.. please see what i'm looking to buy
    http://mp3car.com/vbulletin/showthread.php?t=75182
    Nov 2005
    CT
    Quote Originally Posted by Wiredwrx View Post
    I thought the same thing at first but I think he means cranking up his subs...
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Show me!!!
    Michael
    How's this?:
    or this?:
    To the original poster: Get a H.O. alternator. Your stock alternator is puny compared to the demands your placing on it. A second battery will only allow you to listen to the system longer with the engine off, and will add a bigger load on your alternator; making your problem worse.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 10:10 AM
  2. 2nd battery + computer controlled lighting
    By jparks27 in forum Show off your project
    Last Post: 06-02-2006, 08:52 PM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  4. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-20-2004, 10:08 PM
  5. Problem with tank battery - any good Plan B?
    By Mastiff in forum Power Supplies
    Last Post: 06-14-2004, 09:10 PM
