Results 1 to 10 of 14
Thread: usb non oversampling dac with us in mind
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    So if some of you have followed my threads about talking with someone about making a non oversampling dac with us in mind... our day has come. The guy that i've been talking with has design a dac with high voltage outputs. This dac will be less then the silverstone dac and uses better components. the catch is that you have to build it yourself and it requires soldering surface mount ic's. He is considering building a few complete kits but we'll have to wati and see if it's in the cards.
    here is a link to the nos usb dac:
    http://www.ecp.cc/HPDAC.html
    so lets give this guy some report and you guys handy with the soldering iron should jump on this and forget about those crappy sb soundcards :-)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    wow...i think i hear crickets!
    douglas has added a pre-built price to his website.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Registered User
    This is great news, ive been thinking of ways to eliminate my pxa-701 even if it meant loss of quality/tunning.
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Kalt View Post
    this wont be at a loss of quality. you will probably need a x-over/eq (audiocontrol) or if any front end steps up and makes it possible to use a 1/3 octive 31 band eq, then all you'll need is an active x-over
    M10k
    My Car Pc Install
    My Boat Pc worklog
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    will be keeping a close eye on this one.
    _
    Mar 2004
    Little Elm, Texas
    wow - I'm stunned!
    I couldn't even imagine going there...lol
    I'd go with this unit, if it could be proven that the quality is at least on par with the alpine.
    Jan Bennett
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Red GTi VR6 View Post
    wow - I'm stunned!
    hmmm...i wonder how we can prove it....
    I talked to douglas and he also said he could swap out the mini headphone jack for some rca pigtails.
    from the experience i've had with the headwise usb dac/headphone amp...the sound was leauges above anything i've experienced....but that was also a different...more forgiving audio environment.... using headphones.
    but wow! it was amazing
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Aug 2006
    Any word on this? I'm considering either this unit or the Silverstone. At 195, though, Silverstone is looking better for me.
    Dec 2004
    Los Angeles Ca
    i should have some initial reviews tomorrow when my beyerdynamics headphones come in. it sounds pretty good with my reciever and cheap speaker setup in my room but it's a very poor system that has been abused so i'm not judging it on the sq just yet. This dac can be cheaper ifyou build it yourself. maybe you could work out a discount with douglas if all he has to do is the surface mounted solders and leave the rest up to you.
    just based on design, this dac is much better then the Silverstone. it'll have a higher output voltage and uses better components.
    i'll report back tomorrow or the day after with my initial impressions.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Aug 2006
    Is it possible to add in an AUX input to the dac?
  1. Routing audio from Line-in to usb DAC
    By Preston Masters in forum Car Audio
    Last Post: 10-07-2009, 04:57 AM
  2. USB sound + USB DVD = SLOW
    By TimW in forum General Hardware Discussion
    Last Post: 06-23-2006, 02:19 PM
  3. Self Powered USB help!
    By Jir1984 in forum Input Devices
    Last Post: 06-15-2006, 08:58 PM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  5. are usb 2.0 devices able to work with usb 1.1 hubs?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-28-2004, 08:27 PM
