Results 1 to 10 of 17
Thread: Amp fart noise at turn on
    Aug 2006
    Hi all,
    I have just fitted a 4ch amplifier in my car to drive the speakers and when I turn on the HU the amp power light comes on and after about 5 seconds only what can be described as a farting noise comes from the speakers for about 1 second then the all sounds ok.
    Details of the setup:-
    Car - Vauxhall Astra 2004
    Speakers - fronts are 17cm components with the woofer replaced with aftermarkets. rear door are standard - size unknown.
    Amp - Pure Power 600w (cheapo - but just needed replacement amp for HU with no amp built in)
    HU - Alpine CD/MP3
    I have tried it with RCA's connected to my ipod instead of headunit to eliminate slow RCA powerup on the HU and it still made the same noise.
    I've also moved the ground point for the amp and checked all connections.
    Anyone have any idea what might cause this ?
    Any help really appreciated!!
    Nov 2005
    CT
    Is it like a pop?
    Falls Church, VA
    Quote Originally Posted by swift_gti View Post
    my guess is right here.
    There is a reason why its cheap.
    Aug 2006
    I wouldn't describe it as a pop, its varied it pitch - hard to describe, it sounds like 'ppwerrrp' starts low ends higher.
    Probably doesn't make much sense but its really hard to describe it
    Aug 2006
    Quote Originally Posted by Will Albers View Post
    I hear what your saying - I'm not expecting this thing to be kicking out shedloads of power or anything, but surely it shouldn't do this even if it is lower end of the market!
    Falls Church, VA
    Its the fact that it happens regardless of source that leads me to the idea. Are your gains too high?
    Aug 2006
    No it seems to happen even with the gains turned right down (gain position doesn't make the noise any louder or quieter either)
    I have tried it with my car CD player and notice its picking up noise from the cd player - if i skip track etc it whirrs while seeking.
    Could the remote lead have any impact? I notice theres a small nick in the stereos remote output - Is it possible to test the amp by looping the +12 from the amp to the remote input also ?
    Cheers
    Jul 2001
    Your ground is goofy on your amp. Where is it grounded? It sounds like your amp is trying to ground through the ground braid in your RCAs.
    Aug 2006
    I've tried two different ground points one a bolt coming through from the body work and now its on a factory ground point that has two original items from the car connected to it.
    Is there any way to test out the ground ?
    Nov 2005
    CT
    Does it still make the noise if you dissconnect the RCA's from the amp?
  1. Replies: 94
    Last Post: 09-13-2011, 06:59 PM
  2. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  3. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  4. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  5. Amp turn on problem.
    By RaZor in forum Car Audio
    Last Post: 07-13-2005, 04:20 PM
